Old 10-05-2019, 07:38 AM   #1
RCRV
RCRV is on a distinguished road
Default sl1 2002. What sensors to replace?
Just bought a 2002 sl1 with 125,000 miles on it. Everything seems to work as it should but as preventive maintenance I intend to replace all engine sensors. They are not that expensive and I can do it myself.
My question is what sensors are on this engine? Mass air flow, throttle position, O2, coolant temperature...... any others?
RCRV is offline   Reply With Quote
Old 10-05-2019, 08:36 AM   #2
Waiex191
Waiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of light
Waiex191's Avatar
Default Re: sl1 2002. What sensors to replace?
Here is my take on it. The OEM sensors are pretty awesome. The replacements, not always as good. Every AC Delco part I've recently bought has been from China. I would not replace them proactively, just look for the symptoms. With a 2002 I would expect you have a brass ECTS but I would check the connector for corrosion. The TPS will wear eventually, but this shows up as high or hokey idle and won't strand you. If it was me, I'd research the symptoms for various component failures for the sake of educating yourself, and replace only as needed.
Definitely replace all the fluids. Then you know their status!
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 10-05-2019, 10:00 AM   #3
focusofheart
focusofheart is just really nicefocusofheart is just really nicefocusofheart is just really nicefocusofheart is just really nice
Originally Posted by Waiex191 View Post
...If it was me, I'd research the symptoms for various component failures for the sake of educating yourself, and replace only as needed...
As proactive as I am with how my Saturn runs, I agree with Waiex191.
While your car is still running well, you could take the time to find some OEM parts, if possible, and keep them stored for when you really do need them.
Saturn 1998 - SL2 automatic
Singer 1952 - 301A knee driven
Old 10-05-2019, 12:54 PM   #4
RCRV
Thank you both for your answers.
2002 SL1 - SES, running rich, weird idle - replaced O2 sensors, ECTS, TPS moonlightinred S-Series Tech 10 09-23-2014 05:57 PM
2002 Saturn SL2 stalls ramdonly, I have replaced almost all sensors =( zable82 S-Series Tech 13 04-07-2013 02:49 PM
2002 SC1 engine sensors, coils, injectors, etc MPA Classifieds 1 04-07-2005 01:06 AM
O2 sensors and coil packs replace? Need advise. Son93SL2 S-Series Tech 8 05-28-2001 01:05 PM
