Old 10-04-2019, 09:46 PM   #1
2000sl1blue
2000sl1blue is a glorious beacon of light2000sl1blue is a glorious beacon of light2000sl1blue is a glorious beacon of light2000sl1blue is a glorious beacon of light2000sl1blue is a glorious beacon of light
1998 SW1
2007 SKY Red Line
Default Possible leaking heater core?
What is the easiest way to determine this? I have to top off my coolant about once a year(still green) and I don't see any visible leaks anywhere. However now that it's cold again I recall when I turn on the heat it smells sweet like coolant. Would this be the heater core? I do not smell it on full cold/AC.
Add to 2000sl1blue's Reputation
Rate the quality of this post and help 2000sl1blue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2000sl1blue is offline   Reply With Quote
Old 10-04-2019, 10:40 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Possible leaking heater core?
Do you not use the car very much, only a few miles a week?
If you only have to top it off once a year, I would leave it alone until AND IF something were to really develop a leak.
Still GREEN you say, must have been changed from the factory Orange DexCool at some point in your cars life.
Heater core replacement is a real chore ... most car manufacturers seemingly start with the core, and then build the entire vehicle around it.
Seriously, once a year is not something I would be concerned with. I have had vehicles (some core issues, most not though) that needed top-ups daily.
Old 10-04-2019, 10:59 PM   #3
2000sl1blue
1998 SW1
2007 SKY Red Line
I drive around 450 miles per week maybe more. My thing is I'm thinking it might only leak while I'm using heat since thats the only time I smell it.
Old 10-04-2019, 11:58 PM   #4
lilwhitetruck
lilwhitetruck is on a distinguished road
The heater core in an S series is hands down the easiest heater core I have ever changed. A novice should be able to do it in two-three hours. The absolute hardest part is getting to the clamp hoses just forward of the firewall and that's just because they are installed with the tangs pointed down. After you reinstall them with the tangs pointing up, it really is a piece of cake.
2001 Saturn Silver SC2 Leather Interior with 297K and a newly acquired 2002 White Fully Loaded, With only 87K! My new DD!!!
Add to lilwhitetruck's Reputation
Rate the quality of this post and help lilwhitetruck reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lilwhitetruck is offline   Reply With Quote
Old 10-05-2019, 06:47 AM   #5
onlinebiker
Agreed. But don't tell the civillians...
I got my 02 SC2 cheap - because the kid knew the heater core was leakibg and thought it was a horrible job....
Of course he just put in a bunch of air fresheners and didn't bother to disclose it....
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 10-05-2019, 11:33 PM   #6
lilwhitetruck
Don't ya just love people like that? I've dealt with a few myself.
Old 10-07-2019, 02:10 PM   #7
Coolant flows through the heater core at all times when the engine is running, so the core itself was leaking, it is always leaking. you might only smell it at certain times because it is a very slow / small leak, and you only get it when the flap diverts air through the heater core to warm it up. I would check elsewhere for leaks first because the heater core is the only internal part - everything else in the system is external. It is a small leak so will be hard to spot.
This is the How To with pics in case that is your problem.
http://www.saturnfans.com/forums/sho...d.php?t=150968
heater core leaking tf4cnsff 2008 Vue 0 03-21-2008 07:41 PM
Heater core leaking Blammer S-Series Tech 2 12-13-2007 03:07 PM
heater core replaced still leaking? saturndog S-Series Tech 1 08-11-2007 06:07 PM
L300 Leaking Heater Core piratepress L-Series General 5 12-30-2004 09:41 PM
leaking heater core dg1379 L-Series General 6 05-07-2004 11:11 AM
