Old 09-26-2019, 12:42 AM   #1
dakota1820
dakota1820 will become famous soon enough
Default Wanting to move to a bigger tire
I don't necessarily want to get rid of my sc2 aluminum wheels as they are in good condition. But id like to get a wider lower profile tire. What are some sizes others have run with good results? I know stock is 195/60r15. I'd like to run a good performance all season tire. What size would you adjust to? Want a better handling feel with better stability. Thanks everyone.
Add to dakota1820's Reputation
Rate the quality of this post and help dakota1820 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dakota1820 is offline   Reply With Quote
Old 09-26-2019, 01:27 AM   #2
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Default Re: Wanting to move to a bigger tire
205/60R15 in “H” speed rating on a 2002 SL2.
Mine are HP’s, they have been replaced by the
General RT43’s...
Stable, just wants to go straight...
Mobil 1 ESP 0W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 09-26-2019, 07:15 PM   #3
dakota1820
Should I keep the sidewall at 60 or go lower to 50 or 55
Old 09-26-2019, 07:18 PM   #4
98_Gold_Uranus
98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough
98_Gold_Uranus's Avatar
I'm running aftermarket 16's, but with 225/50's BF Goodrich G-Force Comp 2 tires (WAY overkill spec'ed tire for an SL2 lmao), just about equivalent to a 225/55/15 in size. They're SUPER wide for the small and light SL2, the fronts ever so slightly rub the inner liners at full lock and there's almost no wiggle room between the sidewall and the struts lol, but they do fit. But honestly they're probably too wide for this light weight car. I had the same experience with an S10 that had 225's in the front. The width tends to want to grab and pull the vehicle to one side or the other on bad spots in the road every once in a while. Not bad like it's going to cause a wreck, just noticeable compared to when I had 205's on the same wheels which drove straight as an arrow.
98 SL2, 70k miles, kept in the family since new!
Her name is Uranus :)
Add to 98_Gold_Uranus's Reputation
Rate the quality of this post and help 98_Gold_Uranus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
98_Gold_Uranus is offline   Reply With Quote
Old 09-26-2019, 10:08 PM   #5
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
1997 SW2
If you change the tire size, the overall circumference (distance traveled by a single rotation of your tire) changes and your speedometer, your mileage, and your gearing will all be slightly off/different from before.
Smaller tire height means getting to work will take longer.
Can you afford to take that chance?
• 1997 SW2 used 12/29/2011 with 124,200 -27 mpg
• 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
• 1994 SL1 new traded
• 1992 SL2 new traded for above
Add to dummo's Reputation
Old 09-27-2019, 11:46 AM   #6
dakota1820
I ordered a set of kumho ecsta 205/50r15
When adding a bigger tire? strikers Vue Mods 45 06-22-2012 11:19 PM
Bigger tire question. BLACHE S-Series General 10 08-23-2010 11:54 AM
wanting fog lights mjb1701a Ion Mods 3 11-13-2008 06:52 PM
Wanting to know what to do... budlight78420 Vue General 4 07-17-2008 09:39 PM
Wanting to buy another Satty Chris93SL2 S-Series Mods 7 03-21-2003 12:26 AM
