Old 08-23-2019, 05:25 PM   #1
Keblar
Keblar is on a distinguished road
Default Masking Tape for handling HIR bulb for 9011 mod? Necessary?
I'm doing the 9011 9012 Bulb modification and was wondering if it's safe to mask off the bulb with blue painters tape while I cut away with a Dremel.
Anyone know if this will damage bulb?
Or, if you've done the conversion, is it easy enough just to shield it while wearing nitrile?
2002 SL2 305k + Miles
Add to Keblar's Reputation
Rate the quality of this post and help Keblar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Keblar is offline   Reply With Quote
Old 08-23-2019, 11:05 PM   #2
Default Re: Masking Tape for handling HIR bulb for 9011 mod? Necessary?
The adhesive may not come off completely and cook. If hir lamps heat up hot enough, the glass may shatter from adhesive. Consider cutting a new plastic glove and cut one of the fingers that'll fit over the lamp. A small rubber band to tie off the end. Keep finger oil from touching the glass envelope. Same precautions when handling halogen lamps. Dry air to blow of debris (canned air). Worse case scenario is using an alcohol wipe to clean and remove finger prints and dirt.
Old 08-23-2019, 11:22 PM   #3
Where are you buying the bulbs as most come precut now. Use the nitrile gloves, Just use clean ones right out of the box.
This is where I buy the bulbs. https://store.candlepower.com/hesowisu.html You can find the early ones at a lower price, but you can end up cutting.
If you are concerned about errant fingerprints you can wipe down the bulb with a real Kleenex when done.
Old 08-23-2019, 11:43 PM   #4
Keblar
Cannibalize a glove. Damn, that's a great idea!
I wound up buying a whole round of bulbs for both vehicles from RA, and got a mix of brands to try out some side by side.
Old 08-23-2019, 11:56 PM   #5
The site I linked has all the info on the various generations of those bulbs. I have yet to have one fail but I did rewire the entire drl logic so the high beams are no longer used.
Old 08-24-2019, 12:10 AM   #6
I have to say...using a dremal or any power tool for that matter, on this just sounds about as overkill and stupid as Honda's 200hp lawnmower.
2 snips per bulb with glorified scissors and you're done. Side-cutters...wire cutters...not your wife's clothing scissors. If they're not already in your tool box I'm not sure it qualifies as a tool box
Old 08-24-2019, 09:54 AM   #7
You cut the slits with a dremel and thn take the little flush cutter side cutter to the pa4t that needs to go and clip it out in chunks. May require a bit of cleanup but should not if you are careful. This entire exercise is why you do not buy old stock gen-1 bulbs as all the latest are drop in. The gen-2 early bulb require removing a very small amount off of 1 key to fit easily.
Old 08-24-2019, 01:50 PM   #8
98_Gold_Uranus
98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough
98_Gold_Uranus's Avatar
Maybe I live under a rock... what's this mod for?
EDIT
nevermind, I did a search lol
98 SL2, 70k miles, kept in the family since new!
Her name is Uranus :)
Add to 98_Gold_Uranus's Reputation
Rate the quality of this post and help 98_Gold_Uranus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
98_Gold_Uranus is offline   Reply With Quote
Anyone use TOSHIBA HIR 9011 & 9012 BULBS alleninpa S-Series General 17 02-05-2015 10:40 PM
9011/9012 headlight bulbs for our cars colonelhogan44 S-Series Tech 40 12-06-2014 09:43 AM
Does duct tape fix everything? Kramer5702 S-Series General 7 05-10-2013 04:14 PM
Can't get my cassette tape out :( ngrome S-Series General 4 01-30-2011 04:38 PM
CD/Tape converters w/SL2 tape/Cd drive Deathlok S-Series Tech 5 02-02-2001 01:38 AM
