Old 05-21-2019, 11:13 PM   #1
SomeTech
SomeTech is on a distinguished road
Default 3800 series 2 swap
Me and a buddy are tossing up the idea of stuffing GM's 3.8L v6 into his S-series, to get a platform for racing/upgrading going. He's got the inline 4 in it currently, and I believe it's a 96. It's the 91-2001 model I think, from what I saw on here. Was just wondering if it was compatible, since someone put an LS4 in an L series. If it is, what should we expect to buy, do or remove?
Add to SomeTech's Reputation
Rate the quality of this post and help SomeTech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SomeTech is offline   Reply With Quote
Old 05-22-2019, 06:58 AM   #2
Waiex191
Waiex191's Avatar
Default Re: 3800 series 2 swap
The hardcore S Series hot rodders are over here:
https://sixthsphere.com
Good luck! I have no idea how to answer your questions but I think not a lot is compatible.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 05-24-2019, 01:49 PM   #3
amazinghl
Let me google it for you.
https://www.google.com/search?biw=12...WoYl3y554PXxM:
00 Insight 72mpg
Add to amazinghl's Reputation
Old 05-25-2019, 09:55 AM   #4
Once you custom fab up the mounts & connections it bolts right in, no issue's.
Old 06-04-2019, 04:24 PM   #5
Saturn Night
Stuffing the 3800 Series-II will require some fabrication work and the matching transmission. Use a 1997 Grand Prix GTP tramnsmission, as that was a lone year of the 4T65E Heavy Duty 4-speed automatic.
You will need to cross-reference the wiring diagrams, as the harness from the donor engine/transmission will need to be spliced into the stock Saturn wiring, and you will need to use the PCM from the Grand Prix engine/transmission.
also, plan on measuring the lifespan of your inner, left side tie rod with a stopwatch, as the exhaust manifold will be very close to the rack n pinion.
It can be done.
GM 3800 V6 in a Vue? What do ya think Vue&SL1 Vue General 19 12-16-2007 12:06 AM
Help: Should I Buy 99 SW2 43K $3800?! futubutu S-Series General 19 06-28-2007 09:24 AM
RPMs wont go over 3800 in any gear!?! IZFresh69 S-Series Tech 6 04-14-2007 06:06 PM
1994 Saturn SL2, only 77,000 miles, $3800 dhdh Classifieds 2 06-26-2006 08:44 PM
3800 RalliArt16 S-Series Mods 53 04-20-2006 09:56 PM
