Old 05-12-2019, 01:57 AM   #1
ryanguy426
ryanguy426 is on a distinguished road
Question Another 3 to 2 wire horn conversion thread
I know this has been talked about plenty of times, but I haven't found any solid information on the required relay specifications.
I understand the entire wiring process, and how to hook up the relay. However, I've seen one or two threads saying there needs to be a specific resistance on the relay, or the horn buttons in the steering wheel will get burnt up. 500 ohms is what I've seen, however I also can't find any relays with that high of resistance. The highest I've found is 90 ohms. Would that still be okay, or does anyone know of a specific one that will work safely? The one from All Electronics in Richpin's video isn't sold anymore.
Thanks for any input
1998 White SW1 Auto. Short ram and other mods not worth the time.
Add to ryanguy426's Reputation
Rate the quality of this post and help ryanguy426 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ryanguy426 is offline   Reply With Quote
Old 05-12-2019, 04:07 AM   #2
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Default Re: Another 3 to 2 wire horn conversion thread
RockAuto has 4 pin relays..
https://www.rockauto.com/en/tools/el...ion+relay,3608
Mobil 1 ESP 0W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 05-12-2019, 08:40 AM   #3
"normal" relays only have 50-90ohm's resistance on the coil, the load the horn button's see.
This one has 350ohms as well as a diode built in across the contacts (also recommended) (relay spec's in attachment): https://www.amazon.com/HELLA-0079030...dp/B004NIKZEG/
Hella relay specs are found in this document: https://www.hella.com/hella-us/asset...cs_Catalog.pdf
Old 05-12-2019, 09:04 AM   #4
Waiex191
Waiex191's Avatar
I just used a normal relay I bought off Amazon.
http://www.saturnfans.com/forums/sho...&postcount=103
http://www.saturnfans.com/forums/sho...&postcount=107
OldNuc's warning:
http://www.saturnfans.com/forums/sho...&postcount=108
Works good so far. Another option would be to search through digikey or mouser to find a relay that takes less than 5ma to run that would run the coil of the big relay.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 05-12-2019, 11:08 AM   #5
Waiex191
Waiex191's Avatar
Here is a $5 relay with less than 5mA of current required for the coil. It can handle an amp on its contacts so that would close a normal relay no problem.
https://www.digikey.com/product-deta...1895-ND/385898
Bryan Cotton
Old 05-12-2019, 06:37 PM   #6
ryanguy426
This one has 350ohms as well as a diode built in across the contacts (also recommended) (relay spec's in attachment): (link deleted)
Hella relay specs are found in this document: (link deleted)
That one looks great, however it's a 24v relay and it wouldn't be able to be switched by our 12v system if I recall my (basic) understanding of relays correctly. It seems that's a majority of the relays out there that meet the specs are 24v.
So as long as I test the relay resistance with a multimeter before hooking up the actual horns to it like OldNuc says, any random one off Amazon should suffice? Everything else is clear to me, just the relay choice is what I'm concerned about.
Old 05-12-2019, 07:09 PM   #7
Waiex191
Waiex191's Avatar
I bought these:
https://www.amazon.com/gp/aw/d/B01M7...?ie=UTF8&psc=1
I don't believe they meet OldNuc's specifications for coil resistance or current draw. I took a gamble and haven't lost yet. But if you also buy that little $5 relay, and use it to run the Amazon relay, you would be good. Just make sure you use a diode for suppression on both coils.
Bryan Cotton
Old 05-12-2019, 07:52 PM   #8
When it fails is a function of the use of the horn.
It is not real difficult to find relays on eBay that have a 700+ ohm coil and the power contacts are rated at 30A. The foil contacts in the gen-2 will handle about 50 to 75ma if the arc is suppressed properly.
How to correctly wire 12v 40amp relay for air horn system from 3 wire horn connector? demoncamber S-Series Mods 2 06-20-2013 01:44 PM
Police electric air horn amp conversion? kingkevin8 S-Series Mods 4 07-01-2012 04:04 PM
horn and fuse saw similar thread help irondiezl3 S-Series Tech 7 12-29-2006 07:24 PM
need a 3-wire horn... sc2dave Classifieds 2 05-17-2005 12:37 PM
Please help!!! how do i wire the aftermarket horn ton0831 General Saturn Discussion 2 03-18-2005 08:34 PM
