Old 05-07-2018, 11:55 PM   #41
Default Re: I bought a 99 SC2 slowly bring it back to life.
Timing chain should last the life of the engine. That motor has been operated with less than high quality oil though.
Old 05-08-2018, 08:57 AM   #42
I'm pretty sure the rear seat covers can be removed and laundered in a washing machine (gentle cycle, probably). For sure, the fronts on a DOHC can be removed.
Not positive, as on the SOHC cars, folks have reported that the front seat cover is glued onto the foam. So not sure if Saturn did the same to the rears. It's been about 5 years since I removed a rear seat bottom
http://www.saturnfans.com/forums/showthread.php?t=75536
https://www.youtube.com/watch?v=Rla0xitaOfk
Old 05-08-2018, 10:04 AM   #43
Mark_b
Mark_b is a jewel in the roughMark_b is a jewel in the roughMark_b is a jewel in the rough
@OldNuc we will be switching it to mobile 1 I run that in all my cars my boat and jet skis.
@alordofchaos Thanks for this info. I will be taking them off and putting through the washer that is a great idea.
Some more parts come in today from RA and the trans valve body will be here on Thursday.
Mark_b is offline   Reply With Quote
Old 05-14-2018, 11:36 AM   #44
Mark_b
My knock sensor and oil sensor had the wires broken. I took off the sensors wires added so wire soldered and added heat shrink. The knock sensor had very little wire sticking out maybe 1/8 inch at the wire loom.
In the end I got both of them soldered up and heat shrink on it.
I put new valve body in the transmission. Still not much reverse but I did not expect it to fix reverse without tightening and torquing the input nut.
I drove the car around the yard and when it shifted to second there was no more codes. Actually it has no codes at all right now.
Only one starter bolt was tightened down it looked like the top bolt was to long I put a shorter on in there and tighten it down.
I replaced the air filter. Rebuilt the transmission dog bone.
Old 05-16-2018, 01:13 PM   #45
Mark_b
I ordered two Dorman replacement mirrors. They are black and my son is ok with that.
Hopefully they are decent if not they will go back. They were a better price than a Junk Yard version.
Old 05-16-2018, 02:57 PM   #46
Keep in mind thy are designed to break off, Federal requirement. They can be disassembled and be fixed with JB Weld, don't use the cheap polyester stuff.
Old 05-16-2018, 04:40 PM   #47
Waiex191
Waiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of light
Waiex191's Avatar
I've tested this and can confirm the objective was met.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 05-16-2018, 07:18 PM   #48
I have multiple examples. The true epoxy JB Weld is an effective repair - reinforcement before broke.
Old 05-16-2018, 07:31 PM   #49
Mark_b
I like JB weld but these hacked mirrors would be hard to make them look good.
Old 05-16-2018, 10:23 PM   #50
Yep, those are done for. Save them for the glass in case you manage to break just the glass on one.
Old 05-20-2018, 09:47 PM   #51
Mark_b
I ordered 4 new tires off Walmart.com $177 and I opened CC account and got $25 off first order. The Total was $152 for 4 tires rated 45K with good reviews not too bad.
Old 05-22-2018, 02:39 PM   #52
Mark_b
The driverís manual window is stuck up. I took it apart today and the windows regulator is bad.
I scouted out a replacement on Saturday when I was getting other parts. I did not get it because I had not taken the door apart to make sure what was bad.
I was going to pick it up today but they crushed the car yesterday.
I just ordered a new one ho well. At least the new one has a LT warranty.
Old 05-28-2018, 11:01 AM   #53
Mark_b
My son installed the other wheel cylinder. Back brakes done. We are going to rebuild the calibers and the master cylinder. Flush old fluid.
I installed a new input nut and tightened input and output nut. While I was there I replaced the transmission mount the old one was so bad. Just broken.
I installed the injectors I got from the upick it JY the other day.
The other dog bone needs rebuilt and the top motor needs replaced. They are all not to good.
Walmart put the new tires on the rims under $200 installed not to bad.
Old 05-28-2018, 11:10 AM   #54
The trans and engine mount last much longer with good torque struts and polly inserts.
Old 06-10-2018, 05:22 PM   #55
Mark_b
Top motor mount is just as bad as the trans mount.
Both dog bones are rebuilt. New motor mount installed.
Oil replaced with synthetic oil and new filter.
Transmission fluid replaced and filter. It still had the magnet in there.
Brake calipers rebuilt master cylinder rebuilt and brake fluid flushed.
New ECTS installed.
Reverse is working good now and I drove it in the yard it shifted into second fine.
It my have bad valve seals it smoked when I first started it up but then cleared up.
Old 06-10-2018, 06:30 PM   #56
Bad valve seals are just lived with. That may clear up with an oil brand change.
Some people would never feel a thing until the engine falls out on the ground.
Old 06-10-2018, 09:24 PM   #57
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
Holy crap, I've seen some bad mounts on these forms but there's almost nothing left to that one. It must have felt like a rocket launching everytime you got into the car
97 SL2, auto, 121K miles
Old 06-11-2018, 10:22 AM   #58
Mark_b
Both trans mount and motor mount are the worst I have ever seen. I am sure that was a major reason they sold the car.
We have the door apart and the striped windows regulator out. When we put it all back together we we put on his new mirror.
My son got a Deadpool seat cover he was installing.
Old 06-11-2018, 11:11 AM   #59
You are likely correct, failed mounts forced sale of car as local "mechanic" could not solve clunking and vibration.
Old 06-18-2018, 01:18 PM   #60
Mark_b
The windows regular is installed. We still need to install inner door panel.
I got lucky and got this mirror off Amazon for $6.17 both mirrors total was $27.26 shipped.
Before and after
I think it looks good and we are going to leave in black.
I drove the car about ten miles yesterday. No codes it did shift a little hard I need to reset the adaptive learning.
It handled good pretty darn tight and It ran good.
96 SC2 bringing it back to life (slowly) Mark_b S-Series General 393 09-27-2020 02:45 PM
Bring Back the S Series SL1Joe Suggestion Box 51 09-05-2005 10:19 PM
bring back the s-series crazynate General Saturn Discussion 31 04-12-2005 11:40 PM
Bring Back the Locations!!!! piney Community Center 2 03-10-2003 09:56 PM
Bring back the L100 L100 Suggestion Box 3 11-11-2002 09:05 PM
