Old 06-11-2017, 01:24 AM   #1
vikasevan
vikasevan has a spectacular aura aboutvikasevan has a spectacular aura about
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Default 2004 Vue AWD automatic Random flashing / blinking of low pressure light
When its cold ..no blinking of low oil pressure light on dash but when it gets to about 185 degree it randomly blinks ...
Nothing obvious on how it runs....it runs well...
What ya guys think? could be bad oil pressure sending unit?
or some wiring problem related to this switch?
Also, there is two wire sensor/switch right next to oil pressure sending sensor ...what is that switch/sensor is for?
Rockauto says it is Oil Flow Control Switch; with Gauge and part no. is AIRTEX/WELLS 1S7596 or 12582261 or PS593 ....what does this two wire switch do?it has green color connector
Add to vikasevan's Reputation
Rate the quality of this post and help vikasevan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vikasevan is offline   Reply With Quote
Old 06-11-2017, 02:13 AM   #2
billysvue
Default Re: 2004 Vue AWD automatic Random flashing / blinking of low pressure light
YOu haven't replaced it yet?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 06-11-2017, 02:20 AM   #3
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
I have not replaced it yet because ..I am still not sure if switch is bad ...there is a problem in oil pump ...when I replaced oil ...old oil was too dirty so I am thinking may be pickup screen is clogged...and that could cause low oil pressure ...
when its cold (when oil is thicker) it does not throw light ...it only throw light when its warm ...that makes me think when oil is warm it thins out ...and causes low light to come on..
So what does oil flow control switch do? does it control variable timing?
that switch has anything to do with blinking low pressure light on dash?
Old 06-11-2017, 07:43 AM   #4
billysvue
Looking at the average jug of oil , the first number is the cold viscosity and the second is when it's warm/hot.......................
"when its cold (when oil is thicker) it does not throw light ...it only throw light when its warm ...that makes me think when oil is warm it thins out ."
'17 Suby Forester
Old 06-13-2017, 01:53 PM   #5
Claybury
Claybury will become famous soon enough
Claybury's Avatar
The flow control switch (green) is part of the variable timing.
The oil pressure switch could be bad. If the inside of the connector is oily then the switch is toast. The connector could also be bad. Try a wiggle test.
The best thing to do is to hook up a oil pressure gauge and see what the pressure actually is. If the pressure reads OK, then replace the sender.
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
1974 Triumph Spitfire 3.1L V6
2002 Ram duelly diesel 5.9L
1975 Honda PA50 0.05L (Swarm and destroy)
Add to Claybury's Reputation
Rate the quality of this post and help Claybury reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Claybury is offline   Reply With Quote
Old 06-13-2017, 09:19 PM   #6
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
So this flow control switch (green) has nothing to do with low oil pressure?
Also, when we hook the mechanical pressure gauge ...at the sending unit....does it check pressure before the oil pump or after?
Old 06-13-2017, 09:54 PM   #7
Claybury
Claybury's Avatar
Correct. The flow control switch does not operate the low oil pressure lamp.
The oil pressure switch controls the lamp via the ECM.
Connecting a pressure gauge in the switch location will read the pressure after the oil pump.
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
Old 06-13-2017, 09:56 PM   #8
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Thanks...I will check oil pressure at sending unit soon.
All Dash lights Flashing/Blinking pthurman48 S-Series Tech 26 05-13-2017 10:45 AM
Flashing Check Engine Light - 2004 Vue addicted2mickey Vue Tech 19 01-07-2014 11:21 PM
blinking security/ no start various flashing gauges incl oem radio light. 00SW2 S-Series General 10 08-08-2013 01:47 AM
2003 L300 v6 random flashing service wrench ligh Cranman L-Series Tech 4 12-28-2007 01:14 AM
2004 Tire Pressure Monitor System Light ewalden Vue Tech 2 10-22-2007 11:08 PM
