Old 04-06-2016, 03:25 AM   #21
DrvLikHell
DrvLikHell is on a distinguished road
DrvLikHell's Avatar
Default Re: V6 and S-series engine swap discussion for real :)
Not trying to necro a month old thread, but I was just tooling around and this caught my eye.
A Wankel rotary would be an excellent candidate for a swap. Even though it's not a 6 cylinder (or any cylinder), a 2-rotor Wankel fires six times per crank/eccentric shaft revolution. Non-turbo rotaries from the 2nd gen Mazda RX-7 are diehard and the FCS4 put out 160hp with a very rich factory tune. 300hp is a sneeze for a turbo rotary, and even turbo rotaries can be built to be reliable as long as you know what you're doing and use good parts.
If I had a few extra bucks and a spare S-series, I'd try dropping in an NA rotary. I'd have to try mating it to an AWD transmission too because I've always wanted to tell an STi or an Evo to eat my plastic dust.
As far as an actual six cylinder engine goes... Since Sean R fit an LS V8 from an Impala SS into his SL, I think whatever V6 the Impala had would probably also fit.
Add to DrvLikHell's Reputation
Rate the quality of this post and help DrvLikHell reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DrvLikHell is offline   Reply With Quote
Old 07-05-2016, 11:50 PM   #22
brokendown
brokendown has a spectacular aura aboutbrokendown has a spectacular aura aboutbrokendown has a spectacular aura about
1999 SL
Supernecro!
The rotary is well suited to being down low and compact for a longitudinal mounting - i'm not as sure about transverse which often want a transmission packed next to it - where a tall vertical block is better than a compact small square. Unless you convert it to a longitudinal mounting with all the trimmings but i'd think that would be expensive...
Though if you had something in mind on how you'd put one in i'm all ears.
Not familiar with a V8 s-series (link?) but pretty sure that would be a full custom chassis job, not a factory unibody at all. Even if you could get it in there the torque would be chassis destroying.
Add to brokendown's Reputation
Rate the quality of this post and help brokendown reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brokendown is offline   Reply With Quote
Old 07-06-2016, 12:22 AM   #23
Will.bass
Will.bass has a spectacular aura aboutWill.bass has a spectacular aura about
here ya go. FWD V8. just modded the factory subframe..
http://www.saturnfans.com/forums/sho...d.php?t=215499
Add to Will.bass's Reputation
Rate the quality of this post and help Will.bass reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Will.bass is offline   Reply With Quote
Old 08-26-2019, 09:09 PM   #24
codyhayes
codyhayes is on a distinguished road
Happy Re: V6 and S-series engine swap discussion for real :)
Found this link on the topic: engineswapdepot dot com /?p=9312 specific info on the LS1 V8 engine swap.
I happen to own a 2002 SC2 and also a 2004 Mazda RX8. Both cars were purchased at auction. The RX8 has high mileage but is a rebuilt engine and the Saturn has 114800 miles but has a disappearing coolant problem which could justify an engine swap, just not sure how tricky it might be to swip swap the RX8 regenesis rotary motor into the SC2. Whatever it takes it's not going to be fun during the Arizona summer time.
Cheers!
-Cody
Add to codyhayes's Reputation
Rate the quality of this post and help codyhayes reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
codyhayes is offline   Reply With Quote
Old 08-31-2019, 08:10 PM   #25
2000sl1blue
2000sl1blue is a glorious beacon of light2000sl1blue is a glorious beacon of light2000sl1blue is a glorious beacon of light2000sl1blue is a glorious beacon of light2000sl1blue is a glorious beacon of light
1998 SW1
2007 SKY Red Line
And here I just want a 3 cylinder mirage engine..
Add to 2000sl1blue's Reputation
Rate the quality of this post and help 2000sl1blue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2000sl1blue is offline   Reply With Quote
S- Series Engine Swap chipper58 S-Series Tech 3 05-18-2015 11:51 AM
S-Series Engine Swap chipper58 S-Series General 1 05-18-2015 11:41 AM
L-Series Engine Swap? lucaslindaman L-Series Tech 4 02-28-2014 11:05 PM
Diesel swap discussion? brokendown S-Series Mods 1 08-24-2012 04:58 PM
engine swap to LS series? 99Saturbo S-Series Tech 25 11-19-2009 09:28 PM
