Old 07-09-2012, 09:50 AM   #1
Jess Lookin
Jess Lookin is on a distinguished road
Jess Lookin's Avatar
2002 VUE 3.0L
Default Bolt on hood struts
Took this from herpfreaks on sixthsphere.com for those of you without access.
Hood struts are from a 99 F150.
Larger bolts are from a 99 Chrysler 300.
Smaller bolts are from an 01 Buick LeSabre.
Enjoy !
01 SC2 - Miss Parker - a work in progress
00 SC2 - hibernating
Jess Lookin is offline   Reply With Quote
Old 07-09-2012, 10:49 AM   #2
caveeagle
caveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of light
caveeagle's Avatar
Default Re: Bolt on hood struts
Very nice. Its hard to see in the pics...
Dis you put the ball-stud bolts into existing bolt holes?
caveeagle is offline   Reply With Quote
Old 07-09-2012, 11:30 AM   #3
Jess Lookin
2002 VUE 3.0L
Yes. I used the back bolt on the hood, and the one in the fender is off by about an inch. You just compress the strut a little, and it goes right in.
Old 07-09-2012, 10:20 PM   #4
wi111y
wi111y is on a distinguished road
1995 SL
1995 SW2
What are the bolts called? Ball studs? Would an advance auto have these parts or are they dealer only?
I'm definitely interested in doing this, every other car I've owned had hood struts..
wi111y is offline   Reply With Quote
Old 07-10-2012, 02:26 AM   #5
freelancer1988
freelancer1988 is on a distinguished road
freelancer1988's Avatar
1997 SL1
Dazed Re: Bolt on hood struts
I am more interested in someone making a kit and I buying the so called kit. lol. like 15 plus shipping... Just saying...
freelancer1988 is offline   Reply With Quote
Old 07-10-2012, 05:40 AM   #6
PlasticCarsRock
PlasticCarsRock's Avatar
http://www.redlinetuning.com/QL-SATU...RIES-9102.html
A bit on the expensive side, but a very good product (you get what you pay for). I've had mine for about a year now--the only problem is that I wish I had installed it sooner.
Obviously junkyard parts are going to be cheaper, and may work just as well, but most of these struts have a limited lifespan. I'd rather pay a bit more for the assurance that it will last a long time, and the convenience of a vehicle specific kit.
A single strut may seem a bit unbalanced/asymmetrical, but it holds the hood just fine, and it's nice to have clear access to the passenger side of the engine compartment.
Old 07-10-2012, 08:57 AM   #7
I have the Redline part and agree completely with PCR. That being said the Ford truck used parts is a very nice low cost option for another approach.
Old 07-10-2012, 03:08 PM   #8
Jess Lookin
2002 VUE 3.0L
See, it looks to me like the Redline part is in the same spot as the prop rod. I don't like that spot, it sometimes gets in the way.
Rock Auto has the struts as low as $12.99 each. Grab the bolts from the pick and pull, and order the struts here;
http://www.rockauto.com/catalog/raframecatalog.php
Old 07-10-2012, 03:46 PM   #9
The redline is much further down on the hood than the prop rod. It is about a foot up from the hinge pivot on the fender and about 2 foot on the hood.
Old 07-10-2012, 03:49 PM   #10
Where you place the strut is a function of strut strength, open length and closed length. A short closed length strut will require a high holding force to hold the hood open when the lever arm is short.
Old 07-12-2012, 02:09 AM   #11
NickClubb86
NickClubb86 is on a distinguished road
Enjoy !
How well does the cheap version actually operate? Does it work like it should be there or is it a little funky?
NickClubb86 is offline   Reply With Quote
Old 07-12-2012, 12:03 PM   #12
Jess Lookin
2002 VUE 3.0L
works perfectly. get the bolts from the yard, and order new struts from Rock auto if you're concerned about getting worn struts. I really like how they are completely out of the way too.
Old 09-17-2018, 12:54 AM   #13
jpsuli
jpsuli is a jewel in the roughjpsuli is a jewel in the roughjpsuli is a jewel in the rough
jpsuli's Avatar
1999 SW2
Shot in the dark here, but would anyone know a good replacement for the 99 Chrysler 300 bolt? Amazon and eBay yield the incorrect part, my junkyard had 1 Chrysler 300 like this but had no hood. Anyone know the specific part number who have done this?
Ethel: '97 Saturn SL2 @ 146k (M. swapped)
Un-named: '99 Saturn SW2 @ 92k (M. swapped)
r/Saturn_Cars moderator
jpsuli is offline   Reply With Quote
Old 11-21-2018, 01:34 PM   #14
jpsuli
jpsuli's Avatar
1999 SW2
Found the Chrysler 300 bolts, harder than I thought to find one of these in a JY that wasn't destroyed to bits. Really great mod.
Old 11-21-2018, 01:42 PM   #15
^ ^ ^ looks great! and nice clean engine, too
I really need to do this . . .
Old 11-21-2018, 06:17 PM   #16
Kaervak
Kaervak has a spectacular aura aboutKaervak has a spectacular aura about
Kaervak's Avatar
I have an extra set of the bolts for the mod if you'd like them. jpsuli beat me to the punch and finally got a set for himself.
Kaervak is offline   Reply With Quote
Old 11-21-2018, 10:55 PM   #17
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
This seems like a fun mod to do one weekend. How hard are the parts to come by in the junkyard? And are there other cars they can come from other then the 3 listed in the original post?
97 SL2, auto, 121K miles
Old 11-21-2018, 11:08 PM   #18
Kaervak
Kaervak's Avatar
After comparing the bolts from the 2005 Chrysler 300 to the ones in the original photo and the ones I have on my SL2, the 05 ones are different. They're shorter, I'm not sure they would work for this application unfortunately.
Old 11-23-2018, 09:58 AM   #19
trottida
trottida's Avatar
I came across a post somewhere which outlined the part numbers to order everything from McMaster-Carr. Upper bolt with ball, lower bolt with ball and the right size strut. I can't find the post though.
I've also read that the rear hatch strut from a Honda Del Sol is a perfect match. Here's the post >> Hood Struts. Note that they mount the lower bolt differently by drilling a hole for it and they have to modify the pinch weld for clearance.
Here is the photo from the post ....
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 11-26-2018, 01:49 PM   #20
Thanks, that's very kind of you to offer - but I also have a set of the bolts already
Somewhere in the garage . . . I really should clean it up next spring, now that I theoretically have more time.
I also bought some of the lift struts at the JY but I think I'll buy a new pair when I get ready to do this. I want to paint those bolts first. . . one set came off a white car and they are painted, so they would stand out quite a bit on a red car
Bolt Fairy Strikes! Timing cover middle bolt size? alordofchaos S-Series Tech 8 08-04-2009 11:58 PM
DIY Article: Hydraulic Hood Struts - Replaces Hood Prop Rod Robman L-Series Tech 4 11-09-2008 03:50 PM
Hood Adjustment Struts cam Ion General 0 03-04-2008 02:53 PM
Hood Struts TheGuy S-Series Mods 13 10-18-2006 12:38 PM
Redline Tuning Hood Struts Group Buy at redlineforums.com! handyjoe Ion Red Line 5 08-22-2006 07:29 AM
