Old 04-18-2011, 12:56 PM   #1
RFlaggNY
RFlaggNY is on a distinguished road
Default Backing Plate (a.k.a. Dust Shield) Needed?
Hi Gang,
I've got a '92 SL2. I'm replacing the hub assembly on the right rear wheel. The "Backing Plate" as Saturn calls it rotted away years ago.
I can't find a replacement anywhere. Any suggestions as to where to find a new one?
Do I need one? I'm worried about offsets between the rotor and caliper. Could I use four washers of similar thickness to dust shield as a substitute?
Any thoughts appreciated.
-RF
Add to RFlaggNY's Reputation
Rate the quality of this post and help RFlaggNY reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RFlaggNY is offline   Reply With Quote
Old 04-18-2011, 01:42 PM   #2
Default Re: Backing Plate (a.k.a. Dust Shield) Needed?
Pretty sure you don't need it or spacers, though now that I think about it spacers wouldn't be a bad idea.
Most of the posts I've read about the dust shield is from swapping to rear disks, so maybe look some of those up.
Alternator dust shield missing TomM96 S-Series Tech 3 10-13-2008 06:51 PM
Brake Backing Plate coupster S-Series Tech 9 08-31-2008 10:41 AM
What is improved about the oil pump backing plate 92SC2 S-Series Tech 23 01-02-2008 07:02 PM
exhaust plate/shield rattle.. suggestions? CKyAlliance07 S-Series General 1 04-07-2007 08:34 PM
SELLING a white custom gauge plate with blue backing Dissonanc3 Ion General 9 04-08-2005 01:24 AM
