Old 09-10-2010, 05:57 PM   #1
saturn95
saturn95 has a spectacular aura aboutsaturn95 has a spectacular aura about
saturn95's Avatar
2001 SL2
2007 ION-2 Sedan
Default Oil Plug keeps leaking after oil change even after buying new plug?
After changing the oil on my 01 Sl2 the plug keeps dripping oil slowly!!!I replaced the plug with a new(like I should have done since the beginning) and it stills leaks. I have tried tighten down and nothing. The plug screwed in very nice so there are no striped threads and I don't want to tighten it anymore because then it will strip. Is this a common problem? Should I just get another new plug?Thanks for the help guys.
Add to saturn95's Reputation
Rate the quality of this post and help saturn95 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturn95 is offline   Reply With Quote
Old 09-10-2010, 05:59 PM   #2
LowSC2
LowSC2 is on a distinguished road
LowSC2's Avatar
1999 SC1
1991 SL2
Default Re: Oil Plug keeps leaking after oil change even after buying new plug?
Where did you get the new plug? Some plugs have a plastic washer that doesn't hold the oil in very well. You might need something with a rubber or silicone washer.
Jeff Silva ~ 91 SL2 - 11.809 @ 116.488mph
•Chilton & Haynes manuals are junk
•Changing the ECTS doesn't fix everything
Add to LowSC2's Reputation
Rate the quality of this post and help LowSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LowSC2 is offline   Reply With Quote
Old 09-10-2010, 06:02 PM   #3
saturn95
saturn95's Avatar
2001 SL2
2007 ION-2 Sedan
I got the plug at a local auto part store, it has like a built in rubber washer, but the head was a lot smaller than the one I replaced which was also leaking.
I am assuming that the old one was leaking because you are not supposed to used them again after the oil change.
Old 09-10-2010, 06:34 PM   #4
azrocketman
azrocketman is on a distinguished road
azrocketman's Avatar
1997 SL1
I've always reused oil pan plugs with no problem. I have not seen a requirement for single use on any of my vehicles.
Steve
Add to azrocketman's Reputation
Rate the quality of this post and help azrocketman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
azrocketman is offline   Reply With Quote
Old 09-10-2010, 06:35 PM   #5
saturnsctwo
get a factory plug. mine never leaked ever...
Old 09-10-2010, 06:36 PM   #6
Redhotftw!
Redhotftw! will become famous soon enough
yes. factory replacement.
and lol whoever suggested to you that they are one time use.
you may even want to add your own, thicker rubber washer.
1998 "Red Hot" Sc2
Add to Redhotftw!'s Reputation
Rate the quality of this post and help Redhotftw! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Redhotftw! is offline   Reply With Quote
Old 09-10-2010, 08:18 PM   #7
VUEmaniac
VUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the rough
A thin bead of RTV around the bolt head where the current rubber washer is should take care of that.
Don't blame a clown for acting like a clown. Ask yourself why YOU keep going to the circus.
Add to VUEmaniac's Reputation
Rate the quality of this post and help VUEmaniac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VUEmaniac is offline   Reply With Quote
Old 09-10-2010, 09:32 PM   #8
Redhotftw!
yes. cause that is a better solution then a freaking rubber washer on a bolt you remove every month.
1998 "Red Hot" Sc2
Old 09-10-2010, 10:59 PM   #9
There's a chance that your plug is not leaking at all - take a clean white piece of paper towel and wipe around the oil pan. You may have a leak further up and it is just dripping down to the lowest point on the pan - around the drain plug.
Never heard of one use plug, though I do have a car that uses one-use crush washers for the oil drain plug
Old 09-11-2010, 12:33 AM   #10
Signmaster
The pan might be slightly indented, or have a nick or something. If the rubber washer alone doesn't seal it, grab another washer. I've been using the nylon washers for years now and they work well on all our vehicles. I've used the rubber ones in the past and they work well, but don't seem to be as tough as the nylon IMHO.
Old 09-11-2010, 06:37 AM   #11
vtsl2
vtsl2 is on a distinguished road
vtsl2's Avatar
I got mine at NAPA. Tell them you want an OEM replacement. Mine has worked great for a little over 4 years and 75,000 miles.
SATURNS ROCK: THATS ALL I HAVE TO SAY
01 sc2m mine
93 sc2m my sons
06 chevy 2500 crew 6.6 DMAX
99 sw2a converted to manuel now a race car
02 chevy Silverado extened cab stepside
99 sl2m retired
Add to vtsl2's Reputation
Rate the quality of this post and help vtsl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vtsl2 is offline   Reply With Quote
Old 09-11-2010, 03:21 PM   #12
saturn95
saturn95's Avatar
2001 SL2
2007 ION-2 Sedan
I stopped by the auto store and got some of the rubber gaskets; I already installed it and seems to work, we will see!!!
Old 09-12-2010, 09:56 PM   #13
saturn94v
saturn94v is on a distinguished road
saturn94v's Avatar
1994 SC1
Buy thicker oil.....LOL!...
94 SC1 1.9L SOHC
GM Blue Green
278,429 miles
32+/- AVG/MPG
Add to saturn94v's Reputation
Rate the quality of this post and help saturn94v reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturn94v is offline   Reply With Quote
Old 09-13-2010, 11:44 AM   #14
t&m
t&m is on a distinguished road
Those plastic gaskets they want you to replace every old change and they leak. The rubber you got should work much better and interesting enough are about the same price. I had to replace the gasket on the plug and the replacement rubber has been working well for years now.
Might also check the plug though, any chance someone else changed the oil and may have crossthreaded it or overtorqued it? Me and some friends do a community service for single moms changing their oil and some people really get carried away tightening the oil plug for whatever reason.
Add to t&m's Reputation
Rate the quality of this post and help t&m reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
t&m is offline   Reply With Quote
Spark Plug Change beensmoked L-Series General 8 05-19-2011 02:06 AM
Oil drain plug leaking unkle bik S-Series Tech 9 11-08-2006 12:31 PM
Spark plug change on my 2000 LS2 V6 filter905 L-Series Tech 26 08-24-2006 11:06 AM
When to change plug wires ken b. S-Series Tech 4 01-08-2006 11:45 AM
Antifreeze leaking around spark plug well on SL2 Tiger S-Series Tech 5 06-09-2004 11:34 PM
