Old 07-12-2008, 12:14 PM   #1
2NDSOUT
2NDSOUT's Avatar
1999 SL
Default How To...Remove Radio from 97 SW2
Okay, I did this last night. Took me about an hour, as I wanted to make sure that I did it properly and didn't break anything.
This is a step by step how-to.
Removing the radio from a 97 SW2 (applies to 1995-2002 model year)
Take your time and don't rush as removing these parts are fragile since the plastic is thin. If you rush, you run the risk of breaking something.
Before you begin, undo Negative Battery Cable.
1. Locate push pin "bolts" on each side of the center radio trim bezel.
2. GENTLY push in center of "bolt". It will push in and there will be a small pop of the pin. Do this for each side. Use a small flathead screwdriver and a pair of needle nose pliers to remove these from the sides of the Radio Bezel.
3. GENTLY push radio bezel rearward and lift. Remove electrical connection for 3 Button Switch (Trac Control/Defrost/Fog Light Switch) with small flathead screwdriver. Bezel should now be removed.
4. Locate two small 7MM bolts at top of radio housing. Undo the 7MM bolts; and locate D shaped Flat Metal push levers on each side of radio housing. Push in on D shaped push levers to pull radio out of housing.
5. Undo Electrical connection at back of radio (lower left side), and gently pull out antenna connection on right side.
Install is reverse of removal.
Check to make sure radio works before reinstalling radio bezel. If radio is in Loc mode or displays error message, you will need to call the 800 number that is referenced in other radio posts.
My "new" radio worked fine, and I didn't have any issues with it being locked or error codes.
If you are installing a replacement OEM factory radio as I did, installing another factory radio is plug and play, (95-99 model year radios will interchange with each other).
Pictures below showing removal of base AM/FM radio unit, and install of factory OEM Radio/CD Player. The unit that I installed was out of a 99 Saturn, into my 97SW2
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 07-12-2008, 04:14 PM   #2
Niteshooter
Niteshooter is on a distinguished road
Niteshooter's Avatar
2000 SL2
1999 SL1
Default Re: How To...Remove Radio from 97 SW2
Yup you got it. Factory to factory swaps are pretty easy. Only tricks with a swap to aftermarket are to buy a Metra mounting kit and get an adaptor for the antenna as the stock GM plug is slightly different in diameter to the aftermarket 'motorola' style connectors on the aftermarket radios and this results in poor connections and poor reception.
Kevin
www.kevinomura.com/saturns our Saturn family.
Add to Niteshooter's Reputation
Rate the quality of this post and help Niteshooter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Niteshooter is offline   Reply With Quote
Old 07-13-2008, 04:29 AM   #3
Originally Posted by 2NDSOUT View Post
Removing the radio from a 97 SW2 (applies to 1995-[strike]2002[/strike]1999 model year)
Fixed.
Add to madpogue's Reputation
Old 07-13-2008, 09:49 AM   #4
2NDSOUT
2NDSOUT's Avatar
1999 SL
oops!
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 07-13-2008, 10:17 AM   #5
taxplanner
taxplanner is on a distinguished road
I did the same swap, but went for the cass.
I also pulled the wiring from a junkyard, a two foot cable that pigtails out a connection for the cd changer.
The connector at the end of the pigtail is a white 8mm x 4mm connector, the wires appear to be the same as the wires in the trunk that are for the cd changer. I also cut the trunk cd changer wire, got tired and couldn't trace the connector under the center console.
With the hopes of adding a MP3 player that feeds to the AUX (gm10-aux) will I have to splice the trunk wire into that white 8mm x 4mm connector? or will the 8mm x 4mm connector plug directly into some other P.I.E product?
I would have to think nobody would really want their MP3 player in the trunk.
Thanks,
Add to taxplanner's Reputation
Rate the quality of this post and help taxplanner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
taxplanner is offline   Reply With Quote
Old 07-13-2008, 01:54 PM   #6
Low Saturn
Low Saturn's Avatar
2000 SC2
A printable version is also here:
http://www.differentracing.com/tech_...5-99radio.html
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
-2000 SC2
-2001 Chevrolet Suburban
Old 07-21-2008, 12:45 PM   #7
2NDSOUT
2NDSOUT's Avatar
1999 SL
Could this be moved to the How-To Section as a reference?
If it's not too much to ask Charlie.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
How to remove radio and cassette combo tataat S-Series Tech 6 01-01-2008 09:55 PM
how to remove the radio? chadchism Ion Tech 2 03-13-2006 01:56 AM
2006 Remove radio? lithous Vue Tech 1 09-19-2005 02:39 PM
How do you remove the shifter and radio bezel? blkprl Vue General 9 10-13-2004 02:07 AM
How do you Remove Radio MBman S-Series General 7 10-05-2004 11:08 AM
