Closed Thread
Old 08-16-2004, 05:36 PM   #21
the_skin_eater
the_skin_eater is on a distinguished road
the_skin_eater's Avatar
1999 SL1
Default
Originally posted by amazinghl
Please don't use fram oil filter.
It has lesser filter area, glued cardborad base, problematic rubber anti-drainback valve seals, plastic bypass valves, etc.
http://minimopar.knizefamily.net/oi...study.html#fram
well crap...wish I woulda read this before the weekend. I just cahnged mine and put a fram on it, but then again, thats all we got, dont seem too bad. Cant be all bad considerin the last time my oil was changed was when my bro was drivin it, bouts a year ago, and with a cheap lookin filter...(not my fault)
Im not crazy, just bored...
http://www.cardomain.com/id/the_skin_eater ---Chek it out.
All my time goes to the Talon...My girlfriend is jealous. But my car is jealous that I sleep with her...
Add to the_skin_eater's Reputation
Rate the quality of this post and help the_skin_eater reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
the_skin_eater is offline
Old 09-18-2004, 01:14 PM   #22
walt
walt has a spectacular aura aboutwalt has a spectacular aura aboutwalt has a spectacular aura about
Default
Im a little confused,isnt it ALWAYS right to tighten and left to loosen no matter how your laying or do Saturns have reversed threads?Im asking a serious question since Im planning to start doing my own oil changes on my daughters 01 SC2.
Add to walt's Reputation
Rate the quality of this post and help walt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
walt is offline
Old 09-18-2004, 04:18 PM   #23
Razorbak
Razorbak is on a distinguished road
Razorbak's Avatar
1996 SL2
Default
Yes, if you are facing the top of the bolt head. However, in this case, he is facing the threaded end of the oil drain plug through the oil pan, and reaching behind the oil pan to loosen the head of the plug, so he turns his wrench clockwise, which would be counter-clockwise if he swapped his position by 180 degrees and put himself behind the oil pan facing the head of the plug.
Add to Razorbak's Reputation
Rate the quality of this post and help Razorbak reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Razorbak is offline
Old 09-22-2004, 11:05 AM   #24
eRic 02sc2
eRic 02sc2's Avatar
Default
righty-tighty lefty-loosey
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 09-02-2005, 06:39 PM   #25
Aztek_SC2
Aztek_SC2 is on a distinguished road
Default Re: Changing the Oil Without Jack or Ramp
Originally Posted by eljefino
I hope that moron loses his drain plug down the grate and gets his vehicle impounded when he's walking to buy a new one.
Totally agree with you!!!
2003 Pontiac Aztek AWD
2000 Saturn SC2 - 5 spd
Add to Aztek_SC2's Reputation
Rate the quality of this post and help Aztek_SC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Aztek_SC2 is offline
Closed Thread
Changing Motor Mount, Jack Question Kal S-Series Tech 8 07-08-2008 12:24 PM
Where do I put the floor jack when changing a tranny mount? fixit4mywife S-Series Tech 3 06-04-2008 05:53 AM
Oil change w/o ramps or jack 01SL1SATURN S-Series General 42 01-15-2008 04:05 PM
Homemade Ramp Pit Tercero S-Series General 16 10-24-2007 11:59 AM
Changing floor jack hydraulic oil? bigbird Miscellaneous Tech 2 09-17-2004 04:45 PM
