Old 06-18-2018, 02:05 PM   #61
Default Re: I bought a 99 SC2 slowly bring it back to life.
Looking good.
I probably shouldn't be surprised that there are such a thing as Deadpool car seat covers, but I am a little surprised
Have seen some decent looking ones, though.
Then there's this
Old 06-22-2018, 12:21 PM   #62
Mark_b
Mark_b is a jewel in the roughMark_b is a jewel in the roughMark_b is a jewel in the rough
1996 SC2
1999 SC2
I went to LQK junk yard looking for a driver’s side seat belt but struck out so far. The 99 belt is frayed I used a lighter the get rid of some of the fray.
Color match does not help fine one. The one I found was gray and not in much better shape as the one I have.
The bad part is not shown in the picture. The picture was for me to match the color in the JY
I grabbed some fuses so he has a few extras. I got new plastic insert where the belt goes in maybe that will help not fray it more.
I took back some old parts for the core charge what a scam core charge.
Add to Mark_b's Reputation
Rate the quality of this post and help Mark_b reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mark_b is offline   Reply With Quote
Old 07-23-2018, 12:16 PM   #63
Mark_b
1996 SC2
1999 SC2
My son sprayed degreaser on the motor and transmission and I pressure washed them. Now if there are any leaks we will be able to see where it is coming from.
Old 07-23-2018, 12:33 PM   #64
Get a can of cheap foot powder and a duster. You can gently dust the engine from top to bottom every so often and then inspect. Wash after inspecting though. Normal leak point is the plastic cam cover on the left end, look for oil pooling in the depression between the EGR and head. The other point is the left back side over #3 and #4 cylinders. If you have an aluminum cover it is a non discriminating leaker so check all the way around, also not a common leak point.
Old 08-13-2018, 09:41 PM   #65
Mark_b
1996 SC2
1999 SC2
We put plates on the car and have put on about 50 miles on it so far.
No check engine light. The only issue was we parked on a hill and used the parking brake.
The drivers back wheel was dragging I pulled over and backed up a couple times and it let loose and drove home fine.
I will put it on the lift tomorrow and see what is up the E brake.
Old 08-23-2018, 04:42 PM   #66
Mark_b
1996 SC2
1999 SC2
It looks like when we used the E brake the adjuster fell out and messes up the drum.
I ordered new shoes, new drums new springs, and new adjusters. We already put in new wheel cylinders. I will shoe my boy how to adjust the adjuster before calling it done.
The adjuster wheel was in bad shape.
Old 09-04-2018, 10:48 AM   #67
Mark_b
1996 SC2
1999 SC2
Back brakes are all new. New heater core hose and the car is on the road. My oldest son drove the 99 to school today while his 96 is being worked on to get ready to paint.
Old 09-27-2018, 11:49 PM   #68
Mark_b
1996 SC2
1999 SC2
I added a fixed orifice PCV valve today.
What a good deal at Oreilly auto parts
Old 09-10-2019, 08:12 PM   #69
Mark_b
1996 SC2
1999 SC2
New front rotors the old ones had a wash board feel. New front brakes adjusted back brakes.
New old front seat belt. It works great.
My son has been driving every day now he still has his permit.
Added a can Freon the AC is working so much better.
Old 09-10-2019, 08:45 PM   #70
Now you just need a Saturn for you!
Add to Waiex191's Reputation
Old 09-10-2019, 09:03 PM   #71
Mark_b
1996 SC2
1999 SC2
I work from home so no real need for a car. I do like to drive the boy’s car sometimes.
We have solar and drive a Volt it is very nice to drive on the sun. We sure put alot less miles on our Volt now that my son drives to school.
Old 10-11-2019, 09:32 AM   #72
Mark_b
1996 SC2
1999 SC2
My son and I took out his front seats. We took off the front covers and put them through the washing machine.
We are happy with the results. They are 20 years old so lots of dirt came out.
We will take out the back seats tonight.
The carpet comes out this weekend. Pressure washing time.
Old 10-11-2019, 10:00 AM   #73
Awesome. I never would have thought to do that.
Old 10-11-2019, 10:17 AM   #74
Mark_b
1996 SC2
1999 SC2
Our washer is a LG top load that does not have a traditional washing machine agitator.
It just uses pressure water movement to clean. That works out well for this job.
We washed each part of the cover by itself so the plastic pieces would not harm the other covers.
The covers are outside drying out today.
Old 10-11-2019, 11:25 AM   #75
focusofheart
While your covers are off you might consider resewing the seams. You could even sew in strips of Ripstop Nylon to help reinforce the seams. I would use a good Coats and Clarks Quilting thread with a 18 needle. On anything you hand sew, run the thread through beeswax to make it is easier for the thread to go through the fabric. As a final protection, you can Scotchguard the covers.
Old 10-11-2019, 11:41 AM   #76
trottida
trottida's Avatar
I was going to say "....and add seat heaters!" but then I saw you are in South Carolina. I still use mine in the summer sometimes but they are more of a winter accessory.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 10-12-2019, 03:40 PM   #77
Mark_b
1996 SC2
1999 SC2
The back-bottom bench seat is all we have left to wash. The carpet is washed and drying out.
It is a big improvement.
The spots on the drivers side are burn marks. Last owner must have smoked.
They will get covered up with the floor mats.
Old 10-13-2019, 11:21 AM   #78
Impressive what a difference it makes. Nice work!
Old 10-13-2019, 11:30 AM   #79
Mark_b
1996 SC2
1999 SC2
Thanks. It is raining today. The the carpet is hanging in the garage finishing drying. The car should have a clean smell when we are done.
Old 10-14-2019, 09:06 AM   #80
Mark_b
1996 SC2
1999 SC2
The back-bottom bench seat covers are a real pain to get off. But they washed up very well.
96 SC2 bringing it back to life (slowly) Mark_b S-Series General 392 09-16-2019 12:28 PM
Bring Back the S Series SL1Joe Suggestion Box 51 09-05-2005 10:19 PM
bring back the s-series crazynate General Saturn Discussion 31 04-12-2005 11:40 PM
Bring Back the Locations!!!! piney Community Center 2 03-10-2003 09:56 PM
Bring back the L100 L100 Suggestion Box 3 11-11-2002 09:05 PM
