Old 10-12-2019, 02:45 AM   #1
Rochester
Rochester is a name known to allRochester is a name known to allRochester is a name known to allRochester is a name known to allRochester is a name known to allRochester is a name known to all
Default Momentary high idle, codes 35 and 49
Last week, I rolled over 290,000 miles on the Saturn. Yay! But now the car has given me a new problem to solve.
For the last few days, the car has developed the habit of running a high idle for a few seconds, followed by the Check Engine light coming on. This happens after a few minutes of driving - never immediately after starting when the engine is still cold, but before it has warmed up all the way. When the engine is idle, like if I'm waiting at a red light, it rises over a few seconds to about 1400-1500 RPM, then the Check Engine light comes on and the engine immediately drops back to its normal idle speed of about 700 RPM.
The codes I get are 35 and 49 - "Idle air control RPM out of range" and "Idle RPM out of limit high, vacuum leak" respectively, according to Wolfman's handy-dandy cheat sheet.
Once this happens, there are no further irregularities. I haven't noticed (yet) any changes in performance or fuel economy. It doesn't stall, doesn't run rough, doesn't idle rough, and doesn't idle high again - that is, until I turn off the car and later start it again for my next drive. Not what I'd expect if there was really a vacuum leak (but I'll be looking very carefully tomorrow morning!) It's almost as if the car goes to some kind of backup as soon as it notices something isn't right.
Now I have a project for the weekend, and it might be a good opportunity for me to replace that fuel filter that I keep putting off. That much, at least, I've done before. Anyone have any thoughts about the idling? Thanks!
Rochester is offline   Reply With Quote
Old 10-12-2019, 09:35 AM   #2
Waiex191
Waiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of light
Waiex191's Avatar
Default Re: Momentary high idle, codes 35 and 49
Look for vacuum leaks first. The plastic lines that run around can get brittle. Do you have air injection? Check the hose from the brake booster. You may want to replace the IAC valve if those checks turn up nothing.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 10-12-2019, 10:19 AM   #3
I would clean the connector on the IAC as they either work or they don't and yours is working intermittently. Vacuum leak most likely.
Old 10-12-2019, 10:44 PM   #4
Rochester
Thanks guys. It turned out to be something very simple! I heard a moderate hiss when the engine was running with the hood open, but couldn't pinpoint it by ear alone (slight hearing problems). The hoses all looked ok upon inspection, so it was time for the old Carb Cleaner Test. And sure enough, that did it! When I sprayed around the bottom of the EGR valve, the engine suddenly sounded normal for a few seconds. It turned out that when I replaced the valve this past summer, I hadn't tightened one of the bolts all the way, and that was creating just a tiny leak. I took the thing off and cleaned it, just for good measure, and then put it back and made sure I tightened it all the way this time. And the problem went away!
I'm not sure why three months passed between the time I installed the valve and I started getting the leak. Maybe the changing temperatures had something to do with it; we just got our first cool spell of the autumn last week, and it's been rather cool since then.
2002 SL1; high idle, codes 507, 301 nxne75 S-Series Tech 6 10-28-2016 02:21 AM
94 SL1 High Idle with codes 13 and 32 Scouser S-Series Tech 4 08-01-2016 10:59 PM
2006 2.4L High Idle no codes willyok Ion General 9 07-21-2015 01:42 AM
SL1 2002 High Idle w/ SES codes SL1Queen S-Series Tech 2 06-12-2011 10:37 PM
1997 SL High Idle, EGR DTC codes king_tim S-Series Tech 12 11-06-2008 02:44 PM
