Old 03-15-2019, 11:32 PM   #1
sc2dave
sc2dave is on a distinguished road
sc2dave's Avatar
Default Injector o-ring size
Anyone know the size? I want to buy higher rating ones at oringstore dot com and I need the size ,thanks
www.bold-fortune.com
sc2dave is offline   Reply With Quote
Old 03-16-2019, 01:04 PM   #2
laser3kw
laser3kw will become famous soon enoughlaser3kw will become famous soon enough
2000 SC1
Default Re: Injector o-ring size
What do you mean by "higher rated"? What problem are you having that you are trying to cure?
Here is a resource. you have to figure out which o ring your injector takes and then you can find the dimensions
injector parts resource link
laser3kw is offline   Reply With Quote
Old 03-16-2019, 01:16 PM   #3
RobertGary1
RobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of light
1996 SC2
A solution struggling to find a problem?
-Robert
Old 03-16-2019, 02:41 PM   #4
This might be simpler to lookup what you want: https://www.mrinjectorparts.com/stor...Feed_Kits.html
Old 10-12-2019, 12:15 AM   #5
sc2dave
sc2dave's Avatar
Higher rating, better, or longer lasting,etc. grade
Old 10-12-2019, 10:39 PM   #6
The stock ones should be Viton, or similar, about the best you can get for this application. (Polysufide may be more fuel resistant, but probably poorer for heat). So... as others said earlier this year, what is the problem you are trying to solve by changing the O-rings?
fuel injector o-ring or intake manifold gasket? tan2ksl1 S-Series Tech 7 04-20-2013 12:20 AM
Fuel injector 'bushing' or 'o-ring'? Bossboy302 S-Series Tech 4 02-28-2012 06:32 PM
a/c o-ring size 97sl2DOHCaut1.9 S-Series Tech 4 06-09-2010 08:05 PM
IAC O-ring Size? AndreasChen S-Series Tech 11 09-16-2009 08:51 PM
Injector O-ring injested - cracked head? orneryhermit S-Series Tech 4 07-04-2009 07:23 PM
