Old 10-06-2019, 08:03 PM   #1
Psycho
Psycho is on a distinguished road
1998 SL
Default Thumping noise in front end
I Have a thumping noise in my front end when I go over bumps I just changed out my struts on both sides its not as loud but its still there. I have new lower control arms, new outer tie rod ends, and now new strut assemblies. Only other thing I can think to change is my wheel bearing. Any ideas?
Thanks in advance
Add to Psycho's Reputation
Rate the quality of this post and help Psycho reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Psycho is offline   Reply With Quote
Old 10-06-2019, 09:43 PM   #2
jpags729
jpags729 is on a distinguished road
jpags729's Avatar
Default Re: Thumping noise in front end
Just had this issue and it turned out to be my splash shield...the retaining clip/hook part broke so I installed a new hole and fastener and that has since done the trick. I'd see if that was loose if I was you. Also check your stabilizer bar bushings and the bar itself. Good luck!
Current:
1999 Saturn SL2 1.9 "Sophia Loren 2"
2008 Honda Accord EX-L 2.4
1993 Chevy Camaro Z28 5.7
Previous:
2007 Chevy Malibu LS 2.2
2003 Nissan Altima SE 3.5
Add to jpags729's Reputation
Rate the quality of this post and help jpags729 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jpags729 is offline   Reply With Quote
Old 10-07-2019, 08:49 AM   #3
trottida
trottida's Avatar
Could be the sway bar to engine cradle bushings. The OEM part number is 21011235 and they are only about $12 from RockAuto.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 10-07-2019, 08:32 PM   #4
Psycho
1998 SL
@jpags 729: splash shield? Are u talking about the plastic peace under the front of the car?
Thank you all for the info I will change those check on those bushings.
Old 10-07-2019, 09:06 PM   #5
jpags729
jpags729's Avatar
I meant the splash shield on the sides that you see when you remove the tire. Basically the plastic cover that covers the transmission on the drivers side and on the passengers side the plastic cover that you remove when reaching for the oil filter. They hook into another plastic piece and on my the plastic hook portion broke leaving it hanging a little causing noise.
Current:
Previous:
Old 10-08-2019, 08:25 AM   #6
Drill holes and secure with black tie-wraps.
Old 10-09-2019, 11:28 AM   #7
Psycho
1998 SL
I did that to the bumper on the drivers side
Old 10-09-2019, 03:27 PM   #8
Highmile
Highmile's Avatar
Check your motor mounts
Highmile
'95 SL1 694k and counting
Add to Highmile's Reputation
Old 10-09-2019, 04:48 PM   #9
onlinebiker
They haven't found Jimmy Hoffa yet - so that's a possibility.....
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 10-09-2019, 06:01 PM   #10
focusofheart
Hoffa was in Colorado?
Old 10-14-2019, 10:16 PM   #11
PrestonIII
PrestonIII has a spectacular aura aboutPrestonIII has a spectacular aura aboutPrestonIII has a spectacular aura about
1994 SL2
1994 SL2
You probably need strut bearings. That's the plate on top of the spring that the strut goes through and gets the big nut screwed on the treads on top of the strut to hold it on. There's a bearing in there that allows the strut to rotate when you steer the wheels left to right and back.
This bearing "plate" then goes up in the body of the car, and has three nuts in the engine compartment that hold it up inside the wheel well. Those 3 nuts are where one bolts an aftermarket strut-tower brace to.
They should have been changed when you changed the struts. Last I checked, they were about $60 each. And you have to disassemble the strut assembly to change them!
Be diligent about your testing, and you can probably determine that you might only need one. Hit bumps / potholes with only the left front wheel, then only the right wheel. Faster / slower. See which one causes the noise, and replace that one.
My car only needed the right-side one (They're both the same).
Add to PrestonIII's Reputation
Rate the quality of this post and help PrestonIII reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Thumping noise left front end bigwillie1957 L-Series General 6 11-30-2013 03:48 AM
thumping noise..... 95sc2guy S-Series General 4 04-11-2012 11:09 PM
08 Vue XR Front End Knocking/Thumping Noise johnp3205 2008 Vue 3 01-15-2009 11:15 AM
Right Front Thumping Noise shadow0064 S-Series General 2 03-11-2006 01:13 PM
99 SL1 Thumping Noise Mork S-Series Tech 1 10-25-2004 08:17 PM
