Old 09-30-2019, 09:19 PM   #1
Jozeaph
Jozeaph is on a distinguished road
Default 2003 saturn vue serpentine belt replacement
I got everything out of the way and took my old belt out but I am struggling with the new belt
I'm trying to move the tensioner as the picture but it's not enough
Add to Jozeaph's Reputation
Rate the quality of this post and help Jozeaph reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jozeaph is offline   Reply With Quote
Old 09-30-2019, 10:20 PM   #2
02 LW300
02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all
02 LW300's Avatar
2002 L-Series 2.2L Sedan
Default Re: 2003 saturn vue serpentine belt replacement
Belts can be a pain to install, I would try to slip it over the waterpump pulley last. Sometimes the belt will slip over a smooth pulley easier than the grooved pulleys.
Add to 02 LW300's Reputation
Old 09-30-2019, 10:31 PM   #3
focusofheart
focusofheart is a jewel in the roughfocusofheart is a jewel in the roughfocusofheart is a jewel in the rough
This information was on the forum - there are also youtube videos that could help.
http://www.saturnfans.com/forums/sho...d.php?t=103816
http://www.saturnfans.com/forums/sho...d.php?t=196912
http://www.saturnfans.com/forums/sho...d.php?t=136423
Add to focusofheart's Reputation
Rate the quality of this post and help focusofheart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-01-2019, 12:32 AM   #4
I've removed and replaced my serp belt several times. I agree with 02 LW300, once you rotate the very strong belt tensioner far enough, slipping the belt over the smooth water pump pulley may be easier. This presumes the belt is on every grooved pulley, leaving the water pump pulley last.
Old 10-01-2019, 01:12 AM   #5
Russet
2002 L-Series 3.0L Sedan
And it does help to post the the Vue forum this is for L series Saturn.
Add to Russet's Reputation
Old 10-01-2019, 02:50 PM   #6
Early Vues and L300's share the same 3.0L V6 engine. The timing belt and serpentine belt have the same physical configuration.
Old 10-03-2019, 11:51 AM   #7
Jozeaph
Thanks guys I did it and it worked like magic!!
Replacing serpentine belt on 2003 V6 mr weather Vue Tech 7 10-03-2019 08:07 AM
2008 Saturn Vue XE 2.4L Serpentine belt replacement BNelsonAZ11 2008 Vue 5 02-07-2018 09:46 AM
2003 Ion, Serpentine belt craig4937 Ion Tech 16 11-09-2014 10:57 PM
Serpentine Belt replacement & Is belt dressing ok? 2002SaturnMan S-Series Tech 3 02-14-2010 01:37 AM
2003 L200 Serpentine Belt Jimh64 L-Series Tech 5 08-10-2009 02:16 PM
