Old 09-18-2019, 11:01 PM   #1
TwoFistedJustic
TwoFistedJustic is a jewel in the roughTwoFistedJustic is a jewel in the roughTwoFistedJustic is a jewel in the rough
Default Starter Motor Brands and New vs Reman
There are some 10 year old threads on this subject. I figure they aren't necessarily relevant anymore in late 2019. So I'm creating a new one.
I need to replace my starter on my 02 SC2.
New I see
  • AC Delco Professional 3371165
  • AC Delco GM OE 19260748
  • dbelectrical 17667 "Valeo Unit" - appears to be same ad Power Select unit
  • Duralast (several options)
  • Bosch SR8554N
  • Napa Auto Parts (various, including choice of left or right side terminal??? )
  • Power Select 17667N "Valeo Unit"
  • Pure Engergy 12380N (comes with roadside assistance and tow of unspecified distance)
  • Remy 99700
  • TYC 117667 (Permanent Magnet Reduction - whatever that is...)
  • Valeo 438029
And of course reman units, which I am not considering unless someone can give me good reason to start.
What brands are known to last for a really long time?
Which ones tend to fail after a few years (or less)?
And what's up with the left or right side terminal?
TwoFistedJustic is offline   Reply With Quote
Old 09-18-2019, 11:10 PM   #2
TwoFistedJustic
Default Re: Starter Motor Brands and New vs Reman
I suspect the dbelectrical and Power Select are the same as ECCP 17667N which is somewhat poorly reviewed on Amazon:
https://amzn.to/308NLrY
Manufacturer page here:
https://www.eccppautoparts.com/index...2-d6ra165.html
Old 09-18-2019, 11:26 PM   #3
RobertGary1
RobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of light
1996 SC2
Ive had good luck with the a/c delco pro.
The duralast worked great for several days.
-Robert
Old 09-18-2019, 11:43 PM   #4
TwoFistedJustic
-Robert
And how long has the AC Delco Pro lasted you?
Old 09-19-2019, 06:40 AM   #5
454cid
I would go with either of the Delcos. I put a new AC Delco Professional in my truck and it works great. I didn't realize my original had slowed down until I put the new starter in. I replaced it because it was becoming intermittent. I saved it, and will eventually drop it off for rebuild at a local shop.
I don't think Rockauto had an OE listed for my truck, but other guys had gotten the Professional on the truck forum and thought it to be a good starter.
It's made in Korea not Mexico or China.
The other starter I was interested in, was made by Denso, but it was quite a bit more expensive.
The only real semi-bothersome point for me was that the OEM heat shield doesn't fit without modification. I needed to get the truck going right away, so I left it off. It's a mini-starter and I haven't had any trouble with overheating.
2000 SL2 Automatic (back on the road) 19X,XXX miles.
1999 Chevy K3500
Old 09-19-2019, 07:52 AM   #6
Waiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of light
I'm a DB Electric believer. Mine has 10,000 miles, 17 months, and one new driver behind it. This starter is on my '98. I've replaced the '99 starter several times, a couple times with new units. I don't remember the brands though.
Old 09-19-2019, 08:40 AM   #7
You can spend the extra money for the same starter in an ACDelco box if you want.
Old 09-19-2019, 11:36 AM   #8
RobertGary1
1996 SC2
3.5 years now. I paid $98 for it on Amazon.
-Robert
Old 09-19-2019, 11:40 AM   #9
RobertGary1
1996 SC2
The only issue I have with DB Electric is that availability is fleeting. I got a regulator for my motorcycle by checking the website a couple times a month until I got lucky and found it available.
Right now they don't show a starter for the mid-90's Saturns. Maybe they'll have something next week.
-Robert
Old 09-19-2019, 12:23 PM   #10
Kaervak
Kaervak has a spectacular aura aboutKaervak has a spectacular aura about
Kaervak's Avatar
Quick question, what's wrong with your current starter? If the fuseable link has gone bad from corrosion, that's very easily repairable. About an inch of copper wire and 10 minutes of your time. It happened with my original starter recently, quick and easy repair and its been fine since.
Kaervak is online now   Reply With Quote
Old 09-19-2019, 12:24 PM   #11
They show stock.
https://www.dbelectrical.com/product...02-saturn.html
Old 09-19-2019, 12:33 PM   #12
Installed a DB Electric in April, 2013, and it was still going strong when I parked the car in early 2017.
So, about 4 years of starting at least twice a day, 5 days a week.
Old 09-19-2019, 12:35 PM   #13
blueknigh7
blueknigh7 has a spectacular aura aboutblueknigh7 has a spectacular aura about
1997 SC2
You can get DBElectric from Amazon as well ($52), but I'd go direct to save them a few bucks.
https://www.amazon.com/DB-Electrical.../dp/B007Y85XMG
My first replacement was with a DBElectric at around 140k miles. 7 years later and another 140k miles I have another DB on my shelf waiting for the existing one to die.
blueknigh7 is offline   Reply With Quote
Old 09-19-2019, 08:15 PM   #14
hholbein
I think I've got 10 years and 50K miles on my DB Electrical starter. Unless things have changed, it was as good or better quality than the OEM Valeo starter that croaked at 60K miles. My mechanic (at the time) installed a rebuilt NAPA starter that failed in the first week, so that's why we went with DB Electrical.
Until I replaced my starter, I didn't really know about the 1997 model year's failed fuel pressure check valve issue, so I was cranking the car 2x to 3x every time I drove -- which probably caused the Bendix drive to wear out prematurely.
Anyway, DB Electrical units were cheap, well made, and durable which is why they have a following here.
Old 09-19-2019, 11:19 PM   #15
TwoFistedJustic
I'm skeptical of the dbelectrical starter because it has the same part number as a lot of other generic parts. To be fair those other parts, the ones that have reviews, have decent reviews, none more than 2 years old though.
Even though I am skeptical, I ordered from dbelectrical directly because then any warranty claim I may have will be handled directly through them (not so if you buy from amazon).
I plan to disassemble my current starter to see what's going on inside of it.
Old 09-20-2019, 02:51 AM   #16
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
OE starters are definitely better than any aftermarket one imo. Mine went 22 years before going out. I replaced it with the DBElectric and its been working fine the past year. I do plan on rebuilding my OE starter one day though
97 SL2, auto, 121K miles
Old 09-20-2019, 08:19 AM   #17
First, you can not get the seals you need to properly rebuild that starter and the total available parts cost exceeds the cost of the DB Electric part. No one will turn and undercut the armature commutator for free either and that must be done. You can clean it up and install new brushes and get another year out of it but is is not an cost effective option.
Old 09-20-2019, 09:03 AM   #18
dummo
dummo is a name known to alldummo is a name known to alldummo is a name known to alldummo is a name known to alldummo is a name known to alldummo is a name known to all
dummo's Avatar
I have had a self installed DB Electric in my 1997 SW2 for a few years now, which means I activate the starter anywhere from 1 to 3 times for every start session - due the valve fault in the fuel pump.
It is still going strong.
1997 SW2 used 12/29/2011 with 124,200 -27 mpg
2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
1994 SL1 new traded
1992 SL2 new traded for above
Old 09-20-2019, 10:04 AM   #19
RobertGary1
1996 SC2
Why do you hit the starter? You should be able to just turn the key to run to prime the fuel.
-Robert
Old 09-20-2019, 03:39 PM   #20
TwoFistedJustic
Does anyone have experience with reman starters from Valeo or AC Delco?
starter motor
Starter solenoid to Starter motor wire replacement? pocomenomosso Vue General 7 12-27-2016 08:56 PM
New starter, reman starter or junkyard starter? dbbarney S-Series Tech 9 12-20-2016 11:02 AM
What's the proper breakin for a reman motor? velleguy73 S-Series Tech 11 03-05-2009 09:52 PM
Starter Brands & Flywheel Questions hholbein S-Series Tech 5 02-03-2009 02:48 PM
European brands much more popular than domestic brands 100KSW2 General Saturn Discussion 4 10-07-2003 11:31 AM
