Old 04-22-2019, 09:46 AM   #1
jpsuli
jpsuli is a jewel in the roughjpsuli is a jewel in the roughjpsuli is a jewel in the rough
jpsuli's Avatar
Default SL2 2nd Gen Routing Cables to Upper dash for radio install?
Hello,
I doubt anyone has done this, but I want to put a double din stereo that has Android Auto near the upper dash, right above the middle air vents. I run a tablet above my single din stereo and often find myself looking downward for directions or radio changes, I would like to make the entire radio higher so I don't have to look so down.
Would it be possible to route the cables, once extended, to that point through the dash? I was thinking that the cable could be routed between the middle air vent and the gauge cluster, but I am not sure if there is space under the dash for it. I was going to head to the junkyard this weekend or next to see about removing the dash, but just wanted to gauge an idea from here. I can design a 3D printable case around the double din so that it looks factory. My goal is to place it where my tablet in the photo. I should make it clear that this won't block my field of view! The photo linked is how I view the windshield when sitting in the car, there is at least an inch gap between the top of the tablet and the windshield.
Thanks for any suggestions
'97 Saturn SL2 @ 140k
r/Saturn_Cars moderator
Add to jpsuli's Reputation
Rate the quality of this post and help jpsuli reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jpsuli is offline   Reply With Quote
Old 04-22-2019, 12:49 PM   #2
Default Re: SL2 2nd Gen Routing Cables to Upper dash for radio install?
Take up the dash cover and drop the cable down to the radio, it's a straight shot to either side but the left is easier. Leave plenty of slack and then cut a proper penetration in that tray depression for the cable to connect to the screen. Mount with velcro so the screen can be easily removed and stowed in glove box or with you.
Old 05-01-2019, 01:16 AM   #3
jpsuli
jpsuli's Avatar
A little mockup I made in Fusion 360. Hopefully can make something a bit more pretty. I can't find information on the holes for the screws, it seems to me that different manufacturers use different mounting holes.
Anyhow, just an update to show that this is still a thing
Anyone install radio bracket Metra 99-3100 Dash Kit? JerryHughes S-Series General 13 08-17-2017 06:13 PM
routing satellite radio atenna? morgan Aura General 2 10-09-2007 07:20 PM
Ham radio dash install?? YakVue Vue Tech 3 12-23-2005 12:19 AM
WTB: radio wire and dash install kit 91 SL billzie Classifieds 0 06-30-2005 05:06 PM
Any detailed instructions on breaking down dash for radio install? Blue Goose Vue General 11 01-03-2005 02:38 PM
