Go Back   SaturnFans.com Forums > Models > Saturn Sky > Sky General
Old 10-22-2014, 07:54 PM   #1
performancebowl
performancebowl is on a distinguished road
Default No heat
My 07 sky won't switch over to heat. When I turn the temp knob to heat, I hear a grinding noise in the dash but no heat. Same sound occurs when I switch back to cool/ac. I suspect an issue with the blend door but not sure where to start. Any ideas would be greatly appreciated. Btw, I do have a new control panel I can install if necessary.
performancebowl is offline   Reply With Quote
Old 10-22-2014, 08:49 PM   #2
Default Re: No heat
Try observing each actuator for movement before deciding on whether or not one is broken.
Old 10-24-2014, 11:28 AM   #3
performancebowl
Default Re: No heat
Thanks for the suggestion. I will do that. Any idea how difficult it is to remove the dash to see them or have access to the removal diagram?
Old 06-25-2015, 10:50 PM   #4
MikeNW
MikeNW's Avatar
1997 SL
Default Re: No heat
I don't know about the Sky in particular, but dash INSTALLATION takes minutes at the factory But any car I've worked on in my life was a living nightmare if it needed dash work....
08 Burgman 400
Old 07-08-2015, 07:04 AM   #5
Begather
Begather is on a distinguished road
Default Re: No heat
Agreed with you here.
Begather is offline   Reply With Quote
Old 03-26-2017, 09:15 PM   #6
macantley
macantley is on a distinguished road
Default Re: No heat
yep, i agree, most likely the actuator motor or arm has failed.
macantley is offline   Reply With Quote
Old 07-06-2018, 04:30 PM   #7
m1super90
m1super90 will become famous soon enough
Default Re: No heat
My factory service manual shows that it's a huge job because you have to take the dash frame out, and everything about the dash is mounted to that frame. My ex's blend motor failed over winter, but started working again closer to spring. So, we never got to see just how big a job it is to change.
m1super90 is offline   Reply With Quote
air, dash, heat, noise
no heat/lack of heat problem mr18436572 S-Series Tech 7 04-16-2015 11:01 PM
'04 Vue heat problems (no feet heat) PatrickMcD Vue Tech 5 01-24-2014 05:49 PM
"Heat shield rattle" without a heat shield Modding_out S-Series General 2 01-15-2014 11:58 PM
No Heat in my SC2 Sweetcheeks4565 S-Series Tech 3 01-25-2012 03:22 PM
No Heat in SW2 bluebunny524 S-Series Tech 4 10-18-2006 10:52 PM
