Old 11-19-2005, 04:54 AM   #1
wolfman
wolfman's Avatar
Default "S" Series automatic transaxle fluid/filter change
You will need:
A drain pan capable of holding 2 GALLONS (8 quarts) of liquid
Set of metric wrenches
Oil GOOD filter wrench
RAGS
7 quarts of clean ATF (Mobil 1 synthetic ATF HIGHLY recommended)
Replacement transaxle filter (Buy it from SATURN, not the autoparts store)
Proceed as follows.
Just prior to the day you are going to change the fluid, CHECK IT with the dipstick (HOT in PARK engine RUNNING) to confirm it is full. (You'll understand why later)
The fluid can be changed COLD or WARM (NOT HOT)
1. Remove the air cleaner "box"
2. Remove the battery and battery tray*
*Gives better access to the FILTER, but may not be 100% necessary. IF you have a THEFT DETERRANT RADIO make SURE you have the unlock code BEFORE removing the battery. If you do not, DO NOT DISCONNECT THE BATTERY!
3. Under the car, driver's side, position the drain pan under the transaxle drain plug (differential case) and remove the drain plug. When the plug comes out the fluid will RUSH out VERY QUICKLY, be ready
4. While the fluid is draining, use your oil filter wrench to remove the transaxle filter (turn COUNTER CLOCKWISE) Very little fluid will run out of the filter when it comes off. BE CAREFULL, there are TWO SENSORS mounted in VERY close proximity to the filter. Use caution around the sensors and wires.
5. Wipe off any residue from the filter mount area. If there is a magnet mounted on the filter mounting area, remove it and wipe it off, then replace it ONLY IF USING A FILTER PURCHASED FROM A SATURN DEALER.
6. Smear a thin coat of ATF on the new filter gasket and install the new filter. Tighten it 1/2~3/4 of a turn after the gasket contacts the base. BE CAREFUL not to get any of the sensor wires between the filter and its base, and not to damage either of the sensors!
7. Reinstall the battery, battery tray (if removed) and airfilter box.
8. Under the car, wipe off the drain plug area and reinstall the drain plug.
9. Pour 1 full quart of NEW fluid into the dipstick tube for the transaxle. Then refill the EMPTY bottle with dirty fluid from the drain pan. Continue this NEW in refill bottle with OLD sequence until there is LESS than 1 quart of dirty fluid left in the pan. (You should have 1 empty bottle and maybe 1 or perhaps 2 full ones left at this point)
10. Pour the remaining dirty fluid into the empty bottle. There will be a scale on the side of the bottle so you can tell how much is in it. Using that scale as a guide, add the equivalent amount of CLEAN fluid to the transaxle.
11. Replace the dipstick and start the car. LOOK FOR LEAKS! Especially around the filter! If you spot a leak near the filter, just snug it up a little more. No leaks? Let the car RUN for 10 Minutes
12. With the car RUNNING and in PARK, check the fluid level. It "should" be exactly were it was when you checked it "dirty" as you have effectively put back in the same amount of clean fluid as you drained out dirty. If it needs to be topped up, do it SLOWLY and CAREFULLY a little a time.
Wash your hands and go for a test drive. Recheck the level when you get back.
NOTE: Saturn recommends checking the transaxle level on the dipstick 3~5 times in rapid succession to ensure an accurate reading.
Add to wolfman's Reputation
Old 11-20-2005, 04:08 PM   #2
willfxp
willfxp is on a distinguished road
Default Re: "S" Series automatic transaxle fluid/filter change
I have read that you should shift between all the gears before and after you change the oil. That way you ensure the new fluid gets between all the gears, or something. Is that true?
Thanks,
Add to willfxp's Reputation
Rate the quality of this post and help willfxp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
willfxp is offline   Reply With Quote
Old 11-22-2005, 02:32 AM   #3
sierrap615
sierrap615 is on a distinguished road
sierrap615's Avatar
I've heard that, i can see how it can help and how also it would be worthless. i think it depends on the design of the valve body. i can't hurt anything that wasn't already in trouble.
let me also add the Wolfman's post. before changing the fluid. take a white paper towel. wipe a sample of ATF from the dipstick on the paper towel. if it is red, you are good. if it is a light dark red, its iffy. dark red, brown, or black - DO NOT CHANGE THE FLUID. if you see any grainy materal - DO NOT CHANGE THE FLUID. discolored fluid and grainly partiticiles are signs that the friction materal in the clutch packs have broken down, and friction materal is now curculating in the fuild. now the fiuld is acting as the friction materal in the clutch packs. at this point changing the fluid will result in the loss of that friction materal and result in slipping. also the materal from the clutch pack can dirty up the valve body causing sticking valves(which i have done : ). in short, if the fluid is in bad condicton, do not change the fluid, and a trans rebuild will be needed in time. follow the manufactior's service interval.
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
Add to sierrap615's Reputation
Rate the quality of this post and help sierrap615 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sierrap615 is offline   Reply With Quote
Old 11-22-2005, 05:49 PM   #4
willfxp
What if the color is a light red?
Old 11-22-2005, 07:16 PM   #5
willfxp
Ok, when I did this, I put my car up on ramps so I could get under easier. When I took off the filter, more than "very little" fluid came out. Spilled more fluid than I would have preferred.
Just a note!
Old 11-22-2005, 08:00 PM   #6
willfxp
Maybe I've been inhaling too much ATF... but I don't think the bottle filling adds up.
But if I have an empty bottle, that means the fluid is in the transmission already. So the transmission would be "up one bottle". I'm doing this right now. All the ATF is in my oil container. I pour one new bottle into the transmission, and I pour the old stuff into that bottle. We're one to one. But you need to do that (as stated) in order to stay balanced. I don't see how you can "reverse" that procedure (by pouring the what's left in the can before adding to the transmission) and still stay balanced.
Any tips would be great, other than having an extra empty bottle. Thanks.
Old 11-23-2005, 11:12 AM   #7
Bill Murray
Bill Murray will become famous soon enough
1997 SC1
1997 SC1
I don't want to start a flame war but I disagree with this post.
If your clutch packs are spalling friction material, leaving the old stuff in only makes it worse because you are circulating abrasive material and plugging your filter. As you said the clutch material can "dirty up the valve body causing sticking valves" which I think confirms my opinion. Also the clutch material is abrasive to your gears, bushings, and bearings so your upcoming rebuild will be more extensive. It's always good to change fluid, and while you will find many stories about "I changed my auto trans fluid and the trans failed" it wasn't because of new fluid.
Add to Bill Murray's Reputation
Rate the quality of this post and help Bill Murray reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-23-2005, 10:40 PM   #8
wolfman
wolfman's Avatar
And you would be CORRECT. If the transaxle is in such sad shape that changing the fluid will negatively affect operation, you've been living on borrowed time for a long time..
You can use a clear or other graduated measuring cup if the sequence nets you no final empty bottle. Anything capable of measuring the remaining dirty fluid in Onces or portions of quarts/pints so you know how much more clean to add) can of course be used. (Even an empty soda or beer bottle)
Old 06-04-2006, 01:41 AM   #9
bskicrash1
bskicrash1 is on a distinguished road
bskicrash1's Avatar
Location: Norwich NY 1993 Sukuki GSX-R 750 2002 Kawasaki Ninja 250r
2000 SC2
1996 SL2
Originally Posted by wolfman
You will need:...
...5. Wipe off any residue from the filter mount area. If there is a magnet mounted on the filter mounting area, remove it and wipe it off, then replace it ONLY IF USING A FILTER PURCHASED FROM A SATURN DEALER....
.[/color]
Why not replace the filter with one from autozone that fits the car?
Add to bskicrash1's Reputation
Rate the quality of this post and help bskicrash1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bskicrash1 is offline   Reply With Quote
Old 06-05-2006, 11:43 AM   #10
wolfman
wolfman's Avatar
Aftermarket filters almost without fail have fitment, quality and more importantly FLOW issues. If you had them (an OEM filter from a dealer and a lessor expensive aftermarket one) to compare side by side, the difference is obvious.
I no longer work for Saturn, so I gain nothing by recommending OEM parts.
That being said, understand that if I recommend a particular item such as the transaxle filter be obtained from a Saturn dealer, there IS a reason.
Old 06-06-2006, 12:36 PM   #11
oogy
oogy is on a distinguished road
Suggestions on reading the dipstick?
Maybe I'm a fool but I seriously cannot tell where the level is on the dipstick.
Add to oogy's Reputation
Rate the quality of this post and help oogy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
oogy is offline   Reply With Quote
Old 06-06-2006, 12:39 PM   #12
oogy
Another question..
is mobil1 really that necessary?
I am cool on buying the OEM filter..
but 6$ a quart is nuttery for tranny fluid. (if its worth it i'll do it)
Does the dealer use good stuff when they change it for you?
Because at 60$ paying the dealer to do it would not be a whole lot more than doing it yourself (5x6$ + 10$ for the filter = 40$)
Old 06-06-2006, 12:55 PM   #13
Uzzy
Uzzy has a spectacular aura aboutUzzy has a spectacular aura about
Uzzy's Avatar
2002 SC1
Opinions vary greatly. Just like on engine oil.
My Saturn mechanic friends think so too.
No Well it's good stuff, but not Mobil1 synthetic.
Aut viam inveniam aut faciam
If your ECTS is not brass...your ass is grass.
If you have a problem, if no one else can help, and if you can find him, maybe you can hire Uzzy.
Add to Uzzy's Reputation
Rate the quality of this post and help Uzzy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Uzzy is offline   Reply With Quote
Old 07-06-2007, 12:07 AM   #14
daoyee
daoyee is on a distinguished road
I too am curious of this. I was checking my fluid this evening. I could not even tell where the line was. The fluid on the rag was light red. But seemed translucent on the dip stick.
124,400 Miles
Add to daoyee's Reputation
Rate the quality of this post and help daoyee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
daoyee is offline   Reply With Quote
Old 10-02-2007, 12:00 PM   #15
SW2Fiddler
SW2Fiddler is on a distinguished road
SW2Fiddler's Avatar
1999 SW2
2005 RELAY-2
Idea 2.5 Gallon Drain Pan, Free, plus spigot
I've been preparing to change the fluid (and run the Wolfman Reverse Slam Cure) and have been watching for an appropriate catch pan. Want one that's easy to pour from, into the empty bottles...
My wife wants me to do something with these empty big rectangular Spring Water bottles. One was repurposed to hold dirty fry oil. Another two had the back ends removed which became nice little marinating trays.
I will slice off the top of another 2 1/2 gallon bottle and drain my ATF into it. The spigot should make the filling of empties practically painless.
If it turns out to not be a big enough opening, I will report back right here...
@=(=I-)
Add to SW2Fiddler's Reputation
Rate the quality of this post and help SW2Fiddler reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SW2Fiddler is offline   Reply With Quote
Old 06-07-2006, 03:28 AM   #16
Bigdaddy94sc2
Bigdaddy94sc2 is on a distinguished road
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
Whats up with that?
Cant agree more. Have seen a few trans problems solved by changing fluid and using stock trans filter over aftermarket..... reason maybe?
GM, Saturn, and ASE certified Technician. Always glad to try to help, just ask!!! Now own an 06 ION.2 as of 7/2/06 with 2988 and counting (7/28/06) 13131 as of (1/8/07) 24901 as of (7/30/07)
Add to Bigdaddy94sc2's Reputation
Rate the quality of this post and help Bigdaddy94sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bigdaddy94sc2 is offline   Reply With Quote
Old 08-15-2016, 07:02 AM   #17
buysellny
buysellny is on a distinguished road
Originally Posted by Bigdaddy94sc2 View Post
Whats up with that?
Saturn.is out of business. AC Delco is what I need??
Add to buysellny's Reputation
Rate the quality of this post and help buysellny reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
buysellny is offline   Reply With Quote
Old 08-15-2016, 11:32 PM   #18
Chazberry
Chazberry's Avatar
1995 SW2
The tranny filter of choice is the Wix 57101
Add to Chazberry's Reputation
Old 10-08-2007, 08:46 AM   #19
Commando44
Commando44 is on a distinguished road
Commando44's Avatar
2001 SL2
1994 SL1
If I use a replacement filter from the autopart store, what happens? Can jiffy-lube change my oil? I don't have the time to do it myself.
'94 SL 1
Add to Commando44's Reputation
Rate the quality of this post and help Commando44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Commando44 is offline   Reply With Quote
Old 10-08-2007, 08:04 PM   #20
madpogue
1996 SW2
It'll take less time to change your own oil than it will to contact the BBB, your state's Attorney General's office, your attorney, etc. etc. after they fail to tighten your drain plug, put the wrong product in, fail to do a service for which they charge you, overtighten something, or any of the other host of things for which they're notorious for doing. I wouldn't trust them to change my Christmas tree air freshener.
Add to madpogue's Reputation
S-Series Automatic Transaxle "Reverse Slam Cure-All" plastic torpedo How-To Library 209 11-06-2019 08:31 PM
Plastic Torpedo's S-Series Automatic Transaxle "Reverse Slam Cure-All" Question sdasilva S-Series General 7 08-28-2016 05:34 PM
Automatic Transaxle Fluid & Filter Change TXSaturn02 S-Series General 11 04-04-2007 04:31 PM
Excellent "S" series engine/transaxle pictures wolfman S-Series Tech 4 08-20-2005 04:30 PM
Best "S" Series Engine and Transaxle Pictures wolfman How-To Library 0 08-20-2005 06:04 AM
