Old 04-14-2008, 08:21 PM   #1
quickster
quickster is on a distinguished road
Default Replacing Engine/Trans.Mounts
This week-end, if the weather co-operates, I plan on replacing all TAM components on my 2002 SL-2. My question is, do I loosen and re-torque the two nuts on the engine strut bracket (fore/aft preload) while it's still on the jackstands, or do I wait until the car is sitting on all four tires? Any advice that might make the lower transmission mount easier to change,would be great. At first look, the inner fenderwell looks like it could be in the way when raising the transmission.
Add to quickster's Reputation
Rate the quality of this post and help quickster reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quickster is offline   Reply With Quote
Old 04-14-2008, 08:44 PM   #2
hrbchan
hrbchan is on a distinguished road
hrbchan's Avatar
1997 SL1
Default Re: Replacing Engine/Trans.Mounts
I believe you have to remove the jack under the oil pan or transmission before loosing and tightening the 2 nuts, but you might still need to raise your car or put it on stands, as there is not enough room to get into that area.
It's not that difficult to take the lower engine mount or tranny mount out, but much harder to put the new one back in as the new one is not "compressed" (see attached). I finally used a 2x4 with the cradle as pivot point to move the transmission horizontally for a few mm to let the new one slide in the position. Also, the 2 nuts on the frame side of the top mount should be loosed to give more room for the engine to move. After replacing the bottom tranny mount, replacing the top is a breeze.
Enjoy the "new" quiet and smooth Saturn after the new mounts installed. It's a huge difference.
Add to hrbchan's Reputation
Rate the quality of this post and help hrbchan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hrbchan is offline   Reply With Quote
Old 04-14-2008, 09:07 PM   #3
quickster
Thanks hrbchan.
I'm trying to picture where and how you used the 2x4. I forgot to add that mine is an automatic transmission which is bigger, not much room to raise it. Is yours also an automatic? Was the fenderwell an issue? I'll definitely take your advice on loosening two nuts on engine mount. I was also thinking of loosening the transmission dogbone also, or is it necessary? Thanks again.
Old 04-14-2008, 09:23 PM   #4
hrbchan
hrbchan's Avatar
1997 SL1
Mine is automatic transmission. The fender is easy to remove, only 1 plastic screw, and 1 snap-on.
After I removed the old tranny mount, I found that I need an extra 2mm to slide the new one in. No matter how I jacked up the tranny, the space/gap seems unchanged. Then I tried move the tranny horizontally to the passenger side by using a 3 feet 2x4, as it's not easy to move the tranny by hand. Just that little move, the tranny mount dropped to the position. Then I lowered the tranny slowly to align the 2 holes to put the screws back.
Loose the top tranny dogbone and the top engine mount will help put the new tranny mount back, as it provides more room for movement.
I only replaced the top engine mount and the tranny mount. According to some senior guys like Wolfman said, the dogbones are normally OK, as they are not bearing the weight.
Also see attached a pic of the 2 nuts. There are 3 holes in that area. It's the 2 inside ones.
Old 04-15-2008, 04:44 AM   #5
quickster
Now I understand. Thanks for explaining. I was thinking when you said horizontally, you meant front to back. Now I know exactly. What I meant about the fender was after removing the splash shields, the metal frame or fenderwell at the top, closest to the transmission looks very close to the tranny. But it must not be an issue, so I wont worry about it. I took everything apart to have a look this past week-end, that's why I know the engine dogbone is shot. The transmission dogbone is the only one I didn't investigate, so I figured if I'm going to change the other three, I may as well change that one also. Do you think I should replace any of the nuts, and if so, will the hardware store have them? Thanks hrbchan for all your advice and the pictures are a great help.
Old 04-15-2008, 07:32 AM   #6
JerryHughes
JerryHughes is a glorious beacon of lightJerryHughes is a glorious beacon of lightJerryHughes is a glorious beacon of lightJerryHughes is a glorious beacon of lightJerryHughes is a glorious beacon of light
JerryHughes's Avatar
1997 SL
This may help-----------
http://www.saturnfans.com/forums/showthread.php?t=37578
Jerry
Add to JerryHughes's Reputation
Rate the quality of this post and help JerryHughes reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JerryHughes is offline   Reply With Quote
New Engine/Trans Mounts - still got vibration hydromech S-Series Tech 5 11-01-2009 01:29 PM
Replacing all engine mounts FredM S-Series Tech 24 01-08-2008 01:23 PM
part number for trans/engine dogbone mounts dmc S-Series Tech 2 12-03-2006 11:00 AM
Question about replacing the lower engine and trans mount turbobuick33 S-Series Tech 5 09-06-2006 07:58 PM
4 Engine/Trans Mounts?..... gm7 Miscellaneous Tech 9 05-01-2004 08:11 PM
