Old 10-30-2005, 06:07 PM   #1
greensl2
greensl2 is on a distinguished road
Default 97 SL2 Man Tran lost 2 4 R gears
I have a 97 SL2 with 50k. I have lost the 2 4 and Rev gears, but can run on 1 3 5.
Also, the shifter feels loose.
What's up?
Add to greensl2's Reputation
Rate the quality of this post and help greensl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
greensl2 is offline   Reply With Quote
Old 10-30-2005, 07:10 PM   #2
Default Re: 97 SL2 Man Tran lost 2 4 R gears
One or both of the shifter cable hold on clips at the trans have come off.
Add to ssicarman's Reputation
Old 10-30-2005, 08:18 PM   #3
stu
stu is on a distinguished road
1997 SW2
Welcome to the forum. Here's a little more reading if you are interested:
http://www.saturnfans.com/forums/showthread.php?t=62121
Good luck,
stu
Add to stu's Reputation
Rate the quality of this post and help stu reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
stu is offline   Reply With Quote
Old 10-30-2005, 08:24 PM   #4
S3aturnR
S3aturnR's Avatar
1999 SL1
i concur. sounds like a cable issue. trace those lines carefully to the shift-housing and you will probably find your problem...
s3aturnr
Add to S3aturnR's Reputation
Old 03-05-2006, 05:43 PM   #5
travman514
travman514 is on a distinguished road
travman514's Avatar
Wrench Re: 97 SL2 Man Tran lost 2 4 R gears
hey guy i had the same problem and i found it was one of the shift cable's bracket that broke..so what i did was with my hands make sure the cables were in neutral position,place the part of the bracket that is attached to the cable next to the bracket connected to the tranny and place grip plyers over them clamping down very tight..havent had a problem for 4 months now. i tryed looking for a more permanent fix but after searching the auto parts stores and home depot as well to no avail i gave up....still working great even if it is rigged.....better than buying new cable and bracket!
Add to travman514's Reputation
Rate the quality of this post and help travman514 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
travman514 is offline   Reply With Quote
Old 03-05-2006, 05:48 PM   #6
geartooth94
geartooth94's Avatar
there is a guy on ebay that sells replacement shifter bushings for our saturns for about $30. the only other way to fix it is to buy new shifter cables from saturn ($120 for the part, plus an hour or so for labor)
search for "saturn stick shift" on ebay to find the product.
Add to geartooth94's Reputation
Rate the quality of this post and help geartooth94 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geartooth94 is offline   Reply With Quote
MAN TRANS SWAP SL2-SL1, need help AJMADISON S-Series Tech 9 01-12-2009 07:17 PM
Man tranny 95 SL2 / 97 SC2 swap? jammermeister S-Series Tech 8 02-26-2008 05:03 PM
Confused on how to change transmission fluid for auto tran Sl2 mlambert77 S-Series Tech 16 08-13-2006 08:41 PM
Help just lost all gears after changing valve body feq451 S-Series General 2 06-06-2006 09:06 PM
97 SL2 Man Tran lost 2 4 R gears greensl2 S-Series Tech 2 10-31-2005 09:28 AM
