Old 06-22-2010, 05:17 AM   #1
emsvitil
emsvitil has a spectacular aura aboutemsvitil has a spectacular aura aboutemsvitil has a spectacular aura about
emsvitil's Avatar
Default AC parts diagram/layout..
Is there an online diagram/layout of the AC system on a VUE so I can figure out where all the connections/parts are; and what type of AC system it is?
thanks
Ed
Add to emsvitil's Reputation
Rate the quality of this post and help emsvitil reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emsvitil is offline   Reply With Quote
Old 06-22-2010, 09:08 AM   #2
far2grumpy
far2grumpy's Avatar
Default Re: AC parts diagram/layout..
thanks
Ed ... I've gone through the service manual and don't find an illustration of the AC system. There are descriptions and electrical schematics. Will those help?
I did a Google using Saturn Vue airconditioning system and found several possibles. Perhaps you could find something of value there.
Old 06-22-2010, 03:33 PM   #3
emsvitil
emsvitil's Avatar
I've tried googling, but not with any luck....
I have some knowledge of how AC systems work, rebuilt a couple; so basic descriptions aren't needed.
The R134a has left the building, so the problem isn't electrical.
At the moment, I'm really just trying to find ALL the connections between the parts to look for leaks............
Ed
Old 06-22-2010, 03:56 PM   #4
Chazberry
Chazberry's Avatar
Compressor seal is always a likely candidate. Something like this might help . . .
http://www.thetoolwarehouse.net/p-34...ool-53515.aspx
Add to Chazberry's Reputation
Old 06-22-2010, 04:36 PM   #5
If you insist on finding a leak at any fitting you may lose perspective of the a/c system overall; its a sealed system that can leak refrigerant anywhere. Heat, cold, and vibration along with road debris wears out our systems from expansion, contraction, metal fatigue, chafing, loose fittings, and seal leak. The entire system is inspected from top to bottom visually if an electronic leak detector isn't available. An inexpensive UV light can help to illuminate fluorescent dye installed from the factory in a dark garage or at night. Dye is yellowish green. Refrigerant oil will also leak out and mark the source of a leak. And consider the two service valves as sources of leaks when either the valves aren't tightened or worn and the caps left loose. Some members have found valves leaking when the rest of the system showed no indications of leaking. The obvious sign was bubbling at the valve as some oil leaks past with R134a bubbling out. Look over, under and sideways to spot oil/dye markers. They can show up anywhere. Another member found a clamp had rubbed through the aluminum tubing causing a rupture and release of dye and oil.
gingerman raceway new layout... S3aturnR S-Series General 0 06-16-2010 07:42 PM
Exhaust Layout beensmoked L-Series General 2 12-21-2006 12:51 AM
plug wire layout? Buefordtjustice S-Series Tech 10 10-09-2006 06:40 PM
Next Ion's dash layout golftango Ion General 13 12-31-2003 11:44 PM
