Old 01-11-2009, 06:44 PM   #1
Paddyboy
Paddyboy has a spectacular aura aboutPaddyboy has a spectacular aura about
Default Fuel Gauge not working, 2000 vue
2002 Vue Fuel Gauge not working. I don't have a schematic available. Can anyone give me a little insight? Sensors, relays, harness connections. Any known problems in this area. It's not erratic. looks like no voltage. I also have an air bag light on. I don't know if they came on at the same time. I was thinking mabe they share a common harness connection. all fuses in the car are good. Any insight would be appreciated. This is my wifes car & she's giving me grief.
Add to Paddyboy's Reputation
Rate the quality of this post and help Paddyboy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Paddyboy is offline   Reply With Quote
Old 01-11-2009, 11:00 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: Fuel Gauge not working, 2000 vue
See attached fuel indicator schematic and description from service manual. It appears you'll need specialized test equipment to use the fault isolation table.
Have you used forum search to try locating data for airbag and fuel issues?
Old 01-13-2009, 07:11 PM   #3
Paddyboy
Thanks for the material. It will help. The fuel gauge started to work & the air bag light went out. I think I'm looking for a loose connection. I'll have to dig in when I get the chance. I read in another vue forum about leaking battery post leaking on a ground connection under the Battery. I had that problem with the battery a year ago. I'll start there. Thanks agaian.
air cond. fuel gauge and temp gauge not working. Help?? brielle L-Series General 12 09-14-2016 08:07 PM
2000 LS1 with wacky fuel gauge? pump? What? SloMo2000 L-Series Tech 1 12-02-2007 09:45 AM
Fuel Gauge fails / stops working / goes empty while driving?? [Atari] S-Series Tech 3 07-26-2007 11:20 AM
Fuel Gauge-2005 VUE sportridertex Vue Tech 3 09-19-2006 06:01 PM
Fuel Gauge Stopped Working chris_92_sl2 S-Series Tech 1 04-16-2003 07:19 PM
