Old 06-22-2019, 04:07 PM   #1
TomM96
Default exhaust or muffler Seal
This may be common knowledge, but i was surprised how well some packages of stuff from FLAPS sealed a series of cracks in my downpipe, bordering the Clamp which supports the pipe suspended from (i think) the transmission housing.
This on my 2000SW, acquired last February 2018.
There were a couple of cracks in the downpipe, either side (fore & aft) of the support clamp in front of the flex pipe. The cause was 'galvanic corrosion': the car sat after exposure to roadsalt; the salty (wet) electrolyte allowed the different metals (CLAMP vs DOWNPIPE) to generate a voltage, which then drove chemical dissolution of the downpipe.
I used a hacksaw blade to open/clean the crack. Some washing, sanding clean. Then, paste applied, with a securing cover of fiberglass strips (impregnated with a Hi Temp resin).
The paste, rated 2400*F, i recognized from work repairing ceramic walls of laboratory ovens which ran 10 hours daily at yellow heat:
Blue Magic Quik Steel, Thermo Steel Repair Kit $7.50 @ Advance Auto.
Fiberglass strips: Permatex ExtraWide Muffler & Tailpipe Bandage,
2.85" X 42"; P/No:80332 $6.00.
Intact, functional a year 8000 miles later.
An earlier effort, late 70s, was unsuccessful!
Old 06-22-2019, 05:10 PM   #2
Default Re: exhaust or muffler Seal
One of the miracles of modern chemistry.
Old 06-23-2019, 11:59 PM   #3
saturnsctwo
stuff like that is only temporary. the real way to repair it is to replace the corroded parts.
Old 06-24-2019, 01:34 PM   #4
That Quik Steel paste is pretty impressive. Last month, I used it to patch a spot on the resonator tube, where it turns 90 degrees. It rusted all around where hanger was welded on to the pipe (red circle) so that the hanger was not connected to any metal on the pipe - it was only the Quik Steel that was holding the hanger on to the pipe. It held up fine for many weeks.
What killed it was after several weeks, I had a second spot on the resonator pipe fail - orange line. It rusted and broke right after the flange that bolts onto the catalytic converter. The Quik Steel "weld" held the hanger on for about 15~20 minutes of a drive and I'm sure the resonator pipe was oscillating quite a bit (no longer held at the front) during the drive.
When the Quik Steel finally broke, the resonator hung down low enough to scrape the road
If I did not have that second failure, I am sure the Quik Steel would still be holding.
I was a bit skeptical at first about the product (and all such exhaust products, due to experiences years ago) but not any more
Old 06-24-2019, 06:14 PM   #5
GregS&L
GregS&L is a jewel in the roughGregS&L is a jewel in the roughGregS&L is a jewel in the rough
GregS&L's Avatar
2001 L-Series 3.0L Sedan
Keep in mind that a few states (Virginia included) will fail a state vehicle safety inspection if any exhaust pipes, mufflers, catalytic converters, etc. are found to be “repaired” with patches, tape and/or any type of caulking or paste materials. Many years ago that was not the case but these days things have changed.
Of course if the inspector does not hear an obvious exhaust leak, he or she will probably not look for a “patch” repair job unless it really sticks out.
GregS&L is offline   Reply With Quote
AP exhaust muffler? bh676 L-Series General 0 11-26-2011 09:47 PM
Muffler exhaust help sensei420 S-Series Tech 0 10-07-2011 12:03 AM
how do i change the muffler/exhaust on my 94 sl2? diplomat1 S-Series Tech 11 09-16-2010 12:38 PM
Exhaust Muffler pompidu Ion Mods 9 09-21-2006 05:47 PM
SPS Chambered Muffler Exhaust msbihli Mods and Performance 6 04-03-2002 09:59 PM
