Old 06-07-2019, 01:21 PM   #1
JediTiger
JediTiger is on a distinguished road
Information Engine issues
I have a Saturn SL2 1.9L DOHC
- car started running rough about 3 weeks ago.
- two weeks ago it had been running rough and had trouble starting.
- changed plugs and wires
- has new ignition coils
- started and ran mostly normal
- still running a little rough
- last week it started at work fine and got me home
- the next morning it would crank but not start
- had battery checked' it's good
- has new coils, wires, plugs
- last time it was at Car X they told me 2 cylinders had low compression
- Oil was also old so I changed it
- Added Restore 4 cyl
- It cranks but still won't start.
I figure I have to check the fuel filter and such next but wanted to see what insight you fine folks may have. Thanks for the read!
1997 Saturn SL2 - resting permanently
1999 Saturn SL2 - currently mobile; engine running rough
2001 Saturn SL1 - currently mobile but noisy
JediTiger is offline   Reply With Quote
Old 06-07-2019, 01:53 PM   #2
Dsaturn
2001 L-Series 2.2L Sedan
Default Re: Engine issues
Confirm It is getting fuel. Confirm spark. Do another compression test and post results. Any check engine lights?
Old 06-07-2019, 01:56 PM   #3
Waiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really nice
Welcome! Have you read the sticky?
http://www.saturnfans.com/forums/sho...d.php?t=177672
Have you checked your ECTS and connector?
Old 06-07-2019, 09:31 PM   #4
gveinot
gveinot is just really nicegveinot is just really nicegveinot is just really nicegveinot is just really nice
gveinot's Avatar
2000 SL2
2000 SL2
any codes ? Service Engine Soon bulb burnt out ? Usually an engine with low compression will idle ok.
Old 06-08-2019, 07:44 AM   #5
sc2 saturn
sc2 saturn will become famous soon enough
i would check fuel filter and make sure u can blow through it easy without any restriction and do compression test and fuel pressure test too
sc2 saturn is offline   Reply With Quote
Old 06-08-2019, 09:01 AM   #6
laser3kw
laser3kw will become famous soon enoughlaser3kw will become famous soon enough
2000 SC1
if you get to that point, just throw a new Wix fuel filter on while you are there. Chances are that it needs it
As other said, give it a shot of ether in the TB and see if it pops off. That will at least tell you if it is fuel or spark. Just a 2 second shot - NO MORE!
laser3kw is offline   Reply With Quote
Old 06-25-2019, 12:16 AM   #7
JediTiger
Great! Thanks for the insight.
- Haven't checked engine codes but the light isn't on. Didn't think bulb could be out but I'll check anyway.
- Haven't checked the ETCS or connector. I will read the sticky article and look over that.
Old 06-25-2019, 01:10 AM   #8
See if you can get actual compression numbers...like OBD-II codes just having the description is about as useful as not having anything at all.
The S-Series engine seems to require higher compression (in PSI) than other engines that shops might be used to working on so their idea of "low compression" might actually be "how on earth is the engine running".
engine trouble, sl2, wont start
07 XR Engine issues.. MissBones Aura General 4 03-22-2012 05:02 PM
1997 SL2...engine issues carathers S-Series Tech 3 03-14-2011 06:21 PM
Bad Issues With Engine blink S-Series Tech 12 02-15-2011 02:31 PM
engine issues..please help SL1_sleeper670 S-Series General 12 12-24-2010 11:58 PM
Engine Issues only when A/C is on? mmpotroast L-Series General 1 07-08-2008 09:13 PM
