Old 03-05-2019, 11:27 AM   #1
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
Default Windshield wipers are screwey
Has anybody ever had this problem, When its very cold out side, usually below freezing my wipers will go on by themselves when i start the car and when im driving. Above 32 degrees i dont seem to have a problem. any ideas?
OU812 is offline   Reply With Quote
Old 03-05-2019, 12:44 PM   #2
bluesl2
bluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of light
bluesl2's Avatar
Default Re: Windshield wipers are screwey
Any time I have seen wipers do that on an S-series I just replace the wiper motor, it fixes it every time. Part of the "park" circuit is in the motor itself and starts to fail.
Old 03-05-2019, 01:36 PM   #3
hholbein
1997 SW2
Very likely it's the controller attached to the motor assembly. The controllers on the gen2 and gen3 cars are flaky as hell. The controller reads the input voltage from the steering control stalk (variable resistor) and based on what it sees, it runs different intermittent settings, regular and high. I believe high is 12V, and the one-wipe clear setting is as well.
I don't think new replacement units are available, just "refurbished" units that get a quick black spray paint job. Junkyard isn't a bad option, it's a crap shoot that the replacement controller is better than the bad one you have now.
The controllers can be unplugged/swapped from the wiper motor assembly if you're careful.
Old 03-05-2019, 01:48 PM   #4
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
Rock auto seems to have new motors in the "standard replacement" section.
https://www.rockauto.com/en/catalog/...per+motor,8824
I wouldn't personally recommend getting a remanufactured motor though. Go either new or used from the junkyard. When my original motor died I got it replaced with a remanufactured one, then after 3 months it broke. Got another remanufactured one put in, that one broke after about 4. Decided I would try the junkyard motors and so far it's been way better than the remanufactured ones. Installed it last June and it's only problem is high is no faster than low (is it called low?) but all the intermittent settings work. Which is nice since they kept breaking on the remanufactured ones.
97 SL2, auto, 119K miles
Old 03-06-2019, 08:05 AM   #5
2NDSOUT
2NDSOUT is just really nice2NDSOUT is just really nice2NDSOUT is just really nice2NDSOUT is just really nice2NDSOUT is just really nice
2NDSOUT's Avatar
1994 SL2
1999 SL
Your Wiper Motor is starting to go bad.
I would go to the JY to pull a replacement. Usually you can get a JY Wiper Motor for about $30 +/-
The process of getting to it, is a bit of a bear.
Here is the Richpin video... Enjoy!
https://www.youtube.com/watch?v=KaKXFcDI2rU
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 03-06-2019, 12:21 PM   #6
Saturn Night
Welcome to owning a Saturn S-Series. They collect moisture, in the area where the wiper motor is located. The logic board gets corroded, and they have a plethora of symptoms. One motor, on mine, wouldn't shutoff but only in the rain.
I replaced it, with a JY unit, and the JY unit sprays the windshield with the washer fluid on EVERY setting except the delay settings of 1 & 2. Wiggling my switch, on the dash can sometimes correct it, which means it may be a switch problem as well. I am not pulling my steering wheel, airbag, and clock spring to change it, though.
If you do decide to replace it, try to get a reman unit or new.
Old 03-06-2019, 12:24 PM   #7
Saturn Night
About the ONLY thing that is hard to get to, for repair, on these cars.....lolol
Another reason why I am not replacing mine anytime soon. Pulling the dash cover is not fun, and the tabs tend to break if your aren't careful.
Old 03-06-2019, 08:33 PM   #8
hholbein
1997 SW2
It does take awhile to go through all the removal steps, but there's nothing too tricky about it, and no weird tools either. Just a bit tedious.
93 SL-2 windshield wipers Alwaysdutch S-Series Tech 0 05-11-2007 02:28 PM
Windshield Wipers dalejrfan71 S-Series General 1 08-03-2006 05:05 AM
Windshield Wipers mo615 Ion General 1 12-01-2004 06:24 PM
Windshield Wipers ym42 Miscellaneous Tech 3 11-05-2004 05:19 PM
windshield wipers josh'svue Vue General 3 04-03-2004 02:36 AM
