Old 02-15-2011, 11:08 PM   #1
sattyluvr
sattyluvr is on a distinguished road
sattyluvr's Avatar
2000 SC2
Default Running lights electrical issue
Id love to hear from anyone who has an idea or has had a similar problem.
My rear running lights, fog lights and dash lights are all out. When i replace the 10a fuse and turn the lights on the fuse immediately blows.
My first thought is that it was a short in a socket or bulb so i did the following...
-unplugged all three rear light connectors
-unplugged fog lights
-unplugged fog light switch and dash connector
After unplugging i put a new fuse in and it still blew like before. So now that i assume its not a corroded socket/bulb i believe it might be a pinched wire or the light switch on the steering column itself.
Other info is ...
low beam and high beams in the front still work (on a separate circuit i suppose)
harzards still work
I dont wanna tear the the steering wheel light switch apart until i know a little more about it since theres an airbag ready to go off in my face if i do attempt something.
Any advice that anyone has would mean the world to me. As always thanks guys!
Add to sattyluvr's Reputation
Rate the quality of this post and help sattyluvr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sattyluvr is offline   Reply With Quote
Old 02-16-2011, 02:36 AM   #2
Default Re: Running lights electrical issue
It could be the dash illumination lights, or the front parking lights (they're parking lights, BTW; "running lights" usu. refers to the DRLs). A quick way to remove the dash illumination from the circuit is to disconnect the dimmer. Otherwise, try your same exercise on the front parking lights.
Side marker lights are on that circuit as well.
Add to madpogue's Reputation
Old 02-16-2011, 02:56 AM   #3
sattyluvr
sattyluvr's Avatar
2000 SC2
Yes your right I meant parking lights my bad...forgot i have running lights too. I'll try to disconnect front P lights and see if it still shorts out since i already pulled dimmer switch and dash illumination connector.
I wish the saturn engineers would have put the rear p light on a separate fuse from the front since theyre so important in nighttime driving. i have to figure it out soon because a cop gave me a work order for it to be fixed in 30 days. its also really lame to have to drive around with my hazards on...
Old 02-17-2011, 09:56 AM   #4
sattyluvr
sattyluvr's Avatar
2000 SC2
Ok after checking side and front parking lights to no success i believe i might know whats going on.
Could it be the BCM?...I've been reading about it and if its right behind the glovebox then i might have unplugged it. A couple of months ago it started making vibrating noises and i disconnected mine. I dont know much about its function if anyone cares to share...
Is a junkyard trip in order?
Old 02-17-2011, 10:33 AM   #5
The body control module (BCM) does almost everything the pcm (engine computer) doesn't; internal/external lighting, Passlock theft deterrent system, remote keyless entry, coordinate all diagnostics amongst the computers (ABS/TC, airbags, pcm) and provide a gateway through the DLC link for a Tech II or reader/scanner. If you were to disconnect it there's a good chance the car becomes a large paper weight. Your bcm might be above/below/behind the radio. L-series cars have theirs above the glove box.
Another way to monitor the fused line that keeps blowing fuses would be to wire a 12v tail light in place of the fuse; as long as there's a short or something drawing large current, the bulb stays lit. Now you won't blow fuses and can use the light as a visual indicator while troubleshooting where power is going. Make the two wires long enough so you can place the bulb above the dash and see the light as you go around checking for the short condition.
Anyone perform electrical repairs, mods, rewiring, etc..?
Old 02-17-2011, 10:45 AM   #6
SRGW
SRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of light
1997 SL1
Post Re: Running lights electrical issue
Will these help?
1995 SL1 178,200 and go'in strong!!
CHECK YOUR OIL!!!
Add to SRGW's Reputation
Rate the quality of this post and help SRGW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-17-2011, 11:35 AM   #7
sattyluvr
sattyluvr's Avatar
2000 SC2
lol yea....I haave a 2000 sc2 btw...
Ive had the engine and trans replaced in separate times so who knows ifs theres a pinched wire or what not but thanks for your advice...if i have no bcm in my car then could this be the direct cause of the short or not?
looks like i need a new one installed and programmed
thanks for reply ill do your test still
Old 02-17-2011, 11:36 AM   #8
sattyluvr
sattyluvr's Avatar
2000 SC2
Originally Posted by SRGW View Post
Will these help?
CHECK YOUR OIL!!!
Hell yeah that helps thanks alot! i lost my haynes manual on s-series
Old 02-17-2011, 04:58 PM   #9
It's a bit of a surprise that the car starts and runs with the BCM disconnected. Does the speedometer work? The odometer? The rear defogger?
That said, I doubt it's related to your parking light issue. SRGW's diagram shows no connection between the parking light circuit and the BCM. AFAIK, the only connection between the BCM and any exterior lights is to the turn signal lights, in order for the RKE to flash them.
You received a blessing when you lost your Haynes manual. The Haynes manual for our cars has a bit of information marginally pertinent to the gen-1 cars. It's downright spotty for gen-2, and virtually useless for gen-3. If you're dealing with things like a noise-making BCM, and esp. if you're disconnecting it as a workaround attempt, an FSM set or subscription to AllData will give you much more bang for the buck.
Old 02-18-2011, 01:57 AM   #10
sattyluvr
sattyluvr's Avatar
2000 SC2
hum interesting.
Ive had the BCM disconnected for 2 months so i didnt think it was related but i really dont know. Ive never heard of a bcm before this so i dont understand how it works but if it could cause the engine not to start then i need to replace it anyways
Everything in the gauge cluster works including the check engine light which is on and off because of a small evap leak somewhere
rear defogger also works. Its hard to drive home in the dark from work at night because i cant see the gauges even though they work. I like seeing my tachometer since i drive a 5 spd.
I might take it to the dealer for it and let them find the short and do the bcm just hope its not crazy expensive
thanks for the advice
Night time running lights and dash lights fail Waterboy S-Series Tech 11 04-25-2012 01:35 PM
electrical issue with tail lights sandersdesigns S-Series Tech 9 11-01-2010 07:57 PM
02 Saturn lw300 No running lights or dash lights satrun_hell L-Series Tech 5 02-11-2010 02:47 PM
99 SL2 with electrical issue, running lights flash- instrument cluster haywire Bjorno S-Series General 6 11-25-2009 02:44 PM
Electrical problem - running lights turn on, stay on rx7racerca S-Series Tech 9 10-01-2007 12:17 AM
