Old 07-24-2008, 12:39 PM   #1
gumbysucks
gumbysucks is on a distinguished road
Default 93 sc2 running issue
Runs rough at all speeds. 135k miles, Egr valve was blocked and bad replaced with junkyard one, with new gasket. Also fired up with valve off. New wires, plugs, pcv valve, ects(advance auto), Fuel filter, pulled and cleaned throttle body , iac, reinstalled with new gasket... tried running with exhaust disconnected at front pipe, still same.. codes cleared no new codes.
Any suggestions what to try next??
Add to gumbysucks's Reputation
Rate the quality of this post and help gumbysucks reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gumbysucks is offline   Reply With Quote
Old 07-25-2008, 06:43 AM   #2
BarnOwl
BarnOwl's Avatar
Default Re: 93 sc2 running issue
Pull the DIS module (The square thing under the coils) and make sure it and it's mating surfaces are clean.
Add to BarnOwl's Reputation
Finally fixed my running cool issue! sprinj76 S-Series General 4 12-08-2009 05:15 PM
Running Issue legacy S-Series Tech 5 05-02-2008 06:21 PM
95 Saturn running issue jammeger S-Series General 9 03-01-2008 10:56 AM
My SC2 is running bad, running ruff under a load :( DeMAN S-Series General 7 06-29-2005 12:13 AM
Daytime running and security light issue! Holland1 L-Series General 7 05-13-2005 08:29 PM
