Old 01-09-2019, 08:59 PM   #1
64waves
64waves has a spectacular aura about64waves has a spectacular aura about64waves has a spectacular aura about
2000 L-Series 3.0L Sedan
Default Sudden loss of headlights
Good evening. 2001 L100 approx 175k miles. I have a p0410 code I need to get a part for, otherwise the car runs great. Yesterday I would crank but not start, thought it could be the security system acting up. It started ok today and took it to work. Drove home in darkness, no issues.
Stopped to get gas. After that I pulled onto the road and noticed I had no headlights. I would get the high beams if I did the stalk switch for that.
Rode home on highbeams. I had tail lights, amber lights and dash lights, but no headlights. Brake lights and turn signals also worked. Stalk switch? Fuse? or BCM? Thanks in advance.
Add to 64waves's Reputation
Rate the quality of this post and help 64waves reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
64waves is offline   Reply With Quote
Old 01-10-2019, 09:44 AM   #2
Default Re: Sudden loss of headlights
Check for blown fuses. Next might be the headlight switch.
Old 01-15-2019, 04:04 PM   #3
64waves
Hello, tried a different stalk switch plus checked the headlight fuses and DRL relay. Fuses ok and still no worky.
Old 01-15-2019, 04:38 PM   #4
64waves
I also looked for the headlamp relay at the driver side feet, this car does not have one. What next.
Old 01-15-2019, 05:52 PM   #5
floridasl22002
Found this googling. Maybe helpful to you.
http://www.saturnfans.com/forums/sho...d.php?t=219846
Old 01-15-2019, 05:53 PM   #6
64waves
GOT IT! Tried a bulb on driver side, no help. Tried it on passenger side, got a headlight. So I replaced the driver side with another new one and VIOLA! I have headlights again. I saw a old post in my search that one going out could cause the second one to go out. I really don't think I had one out for a while then the second one finally went. But GLAD it is working now. I do have more bulbs on hand just in case. Yippee!
Old 01-15-2019, 07:54 PM   #7
Both low beam lamps burned out? No wonder we all missed it. One low beam is obvious, not two.
93 SW2 sudden loss of oil pressure onlinebiker S-Series Tech 8 01-14-2019 02:10 PM
93 SW2 sudden loss of oil pressure onlinebiker S-Series Tech 4 05-18-2018 08:11 PM
sudden power loss. scbill S-Series Tech 21 05-11-2016 05:17 PM
sudden loss of power.......... Nicktheviperman S-Series Tech 7 05-02-2014 11:44 PM
Help with Sudden Oil Loss AndreasChen S-Series Tech 15 01-19-2010 02:58 AM
