Old 01-14-2019, 02:23 AM   #1
mylego1017
mylego1017 is on a distinguished road
Attention warning lights come on when turning
i have a 2008 VUE with approx 170,000 miles, lately when i make a turn (most of the time its a right turn) the Traction off light, brake light, and the other light dealing with traction and stability come on and the brake on sound beeps a few times, then the beeping stops and brake light goes off but the other 2 stay on until i turn car off. Any possible ideas on causes?
Add to mylego1017's Reputation
Rate the quality of this post and help mylego1017 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mylego1017 is offline   Reply With Quote
Old 01-14-2019, 05:28 PM   #2
JefferyC
JefferyC is on a distinguished road
JefferyC's Avatar
Default Re: warning lights come on when turning
Check your brake fluid at least.
Add to JefferyC's Reputation
Rate the quality of this post and help JefferyC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JefferyC is offline   Reply With Quote
Old 01-14-2019, 07:13 PM   #3
far2grumpy
far2grumpy's Avatar
I've attached ABS/TCS/SCS explanation extracted from service manual (apologies if you understand system).
Similar problems have been caused by loose or damaged wheel speed sensor connector (WSS) or interconnect wiring to EBCM.
A "tired" WSS could also be failing by not sending expected signal at low speeds to EBCM.
Its likely one or more trouble codes have been stored to identify the problem. GM dealers and better repair shops will have a code reader to read codes and most likely isolate problem to specific area.
A few questions:
1. are the turns low speed type (not highway driving)?
2. do you need brake pedal pushed when turning to cause lights?
3. if FWD - can you lift front end - run engine in gear at slow speed and turn steering wheel to see if you can duplicate problem?
I don't spend much time on forum but do answer private messages (they alert my phone). Include email address if you need pdf extracts. Don't use visitor message feature as I forget to check those.
3 warning lights on. st1speed Vue Tech 2 12-27-2014 07:52 PM
Warning Lights Rthart3 Aura General 10 11-14-2011 11:22 PM
What do these warning lights mean? Athey S-Series Tech 4 09-13-2011 12:33 AM
Brake warning and ABS warning lights 1tuffref S-Series Tech 16 01-06-2008 09:00 PM
Problem with engine turning on then turning off, everything is on radio, lights, air fatimaknapp Ion Tech 6 12-28-2006 05:02 PM
