Old 01-12-2019, 11:13 PM   #1
carlbo
carlbo is on a distinguished road
1993 SW2
Default TAM #21011170 question.
The only part number I'd ever heard of was #21012185 which has been discontinued. Someone is selling, online, a Saturn TAM with this #21011170. What is this and who manufactures it? Is it an older revision design? Seller wants a whole lot of money.
Add to carlbo's Reputation
Rate the quality of this post and help carlbo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
carlbo is offline   Reply With Quote
Old 01-12-2019, 11:48 PM   #2
Default Re: TAM #21011170 question.
One is the OEM frowny design, the other the OEM solid.
No truly new OEM engine mount exists, they're all 5+ years old as they haven't been produced in at least that long.
'92-'95ish got the solid design, '95ish-'97ish got the frowny design, '98ish-'02 got the solid design again. '91 got a unique engine mount.
Old 01-13-2019, 11:18 PM   #3
Saturn Night
1991 was the "invisible" TAM mount, as the head wasn't cast for the mounting studs and the upper mount wasn't added, until 1992, due to the complaints about NVH levels.
Old 01-14-2019, 10:08 AM   #4
trottida
trottida's Avatar
With the exception of the 91 model year the OEM mount was sold under the same part number (21012185) in both frownie and solid designs however I see what you mean in the eBay ad for a used 1997 engine mount.
https://www.ebay.com/itm/1997-SATURN...-/113402800395
The tag says it is from a 2001 S Series and that part number shows as raised lettering in the rubber of the mount. The 210 prefix does seem to indicate an OEM part. It has been mentioned in posts before on this site >> '98 SW2 upper engine mount numbers
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Horn question...(Possibly a dumb question) ninetynineSC2 S-Series Mods 8 02-18-2013 10:01 PM
Fog Light Cover Question and Ignition Question macman90 L-Series General 1 06-23-2009 10:32 AM
Newbie Question - Size of Air condenser compared to radiator? Also airbag question. 2002SaturnMan S-Series General 9 04-18-2006 09:53 AM
Ring job question and timing chain question Preachermannn S-Series General 5 03-10-2005 02:40 PM
Question on replacing differential cover gasket ( non-Saturn question) Mark G Miscellaneous Tech 3 10-27-2002 01:50 AM
