Old 01-12-2019, 11:39 PM   #1
prioris
prioris is on a distinguished road
Default EGR Error Code P0401
I have a P0401 code problem on 1999 Saturn SL1. I am in Florida.
The sequence of events ...
Not sure if this is relevant ... I found I had a catalytic problem so had that replaced. The guy ask me if I wanted to just put a straight pipe alone and I said no because I was aware of some people having computer problems and thought I could avoid them so he offered to put in a catalytic converter he had laying on side. Total cost was $150. I don't put much mileage on car yearly so should last until end of century. No more catalytic problems. Car runs fine.
So after a couple days, I started getting the code problem. We took the EGR valve out, cleaned it and replaced the gasket then put back in. The valve was really dirty. So tried it again. Same error code. It's a seemingly benign problem ...
Any ideas on how to solve it ?
Add to prioris's Reputation
Rate the quality of this post and help prioris reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
prioris is offline   Reply With Quote
Old 01-13-2019, 12:16 AM   #2
Cheyne
Cheyne will become famous soon enoughCheyne will become famous soon enough
2000 SL2
Default Re: EGR Error Code P0401
Warm up the car. Remove the EGR valve and start the engine briefly. It should rev to the limiter and blow carbon out of the port. You will also want to make sure the EGR valve is sufficiently clean.
Add to Cheyne's Reputation
Rate the quality of this post and help Cheyne reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cheyne is offline   Reply With Quote
Old 01-13-2019, 10:14 AM   #3
prioris
I have done both those things.
Old 01-13-2019, 11:25 AM   #4
Most likely the valve is shot. Best bet is a pick and pull yard that will let you bring back duds. Look for any 99 to 94 model Saturn with the same electric EGR. Go on 1/2 price day and pick one up. They are expensive new and are prone to be junk out of the box. Once replaced pull the PCM B fuse for a couple of minutes to get the PCM to reset the closed position value.
Old 01-13-2019, 10:05 PM   #5
prioris
Thanks
code P0401 on SL1 99 skydiveboy S-Series General 6 09-12-2014 04:07 PM
98 SL1, P0401 code. kryten S-Series Tech 22 12-24-2013 02:18 PM
p0401 code question drunk horse S-Series Tech 2 07-13-2012 11:08 PM
P0401 code question leicaman S-Series Tech 2 04-25-2010 08:15 PM
Trouble Code P0401 EGR Satman53 S-Series Tech 2 05-21-2008 06:59 AM
