Old 01-09-2019, 06:06 PM   #1
cgg17
cgg17 will become famous soon enoughcgg17 will become famous soon enough
cgg17's Avatar
1995 SL2
Default Seat Foam Interchangability
Hello all,
The front two seats on my 1995 Sl2 are getting saggy and the side parts are especially saggy. I saw a 1999 SC2 being parted out, and wanted to know if the seat bottoms are the same? They appear the same, with the square leading edge and high bolstering on the bottom.
If anybody has information on seat foam interchangeability, I am all ears.
Thanks,
Chris
1994 Sl2 5spd: 56,576 (Totaled 1/10/2018)
1995 Sl2 5spd Manual Swap: 150,062
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-10-2019, 01:05 AM   #2
Default Re: Seat Foam Interchangability
Easier and faster to simply bolt the SC2 seats in. Verify the seat belt has the same size/style on the latch on both cars, '99 was the change over year and it's much easier to swap the seat mounted bit while the seats are out of the car.
The passenger seat would be a bit odd going from the SC2 to the SL2; the 4dr models don't have a slide-forward passenger seat while the 2dr & 3dr's do. You'd probably never notice, but its worth mentioning.
Other than the buckle the front seats are interchangeable '91-'02, though DOHC seats have a bit more side bolstering as well as adjustable head rests and adjustable lumbar support on the driver seat.
Old 01-10-2019, 01:20 AM   #3
cgg17
cgg17's Avatar
1995 SL2
I may just pick the seats up and try it. I am looking to retain my original seat covers, as they are the way the car appeared back in the day (I am one of those interior must be stock freaks).
What do you mean by slide forward? The seat slides forwards and backwards on all of the S-Series that we have. Unless you mean the knob on the drivers left side where you can make it go up/down?
Old 01-10-2019, 02:01 AM   #4
Zeebins
Zeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to all
Zeebins's Avatar
I think the seats from the coups move further than the wagon/sedan seats to make it easier to get into the back seats.
Road salt will be the death of me
1997 SL2, 112K miles
Add to Zeebins's Reputation
Old 01-10-2019, 02:42 AM   #5
cgg17
cgg17's Avatar
1995 SL2
That would make sense. That actually makes a lot of sense!
Old 01-10-2019, 07:32 AM   #6
Waiex191
Waiex191 has a spectacular aura aboutWaiex191 has a spectacular aura aboutWaiex191 has a spectacular aura about
Waiex191's Avatar
The seat contours of my '98 SC2 seem a lot different than my '99 SL2. I don't think the foam would swap.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 01-10-2019, 09:29 AM   #7
trottida
trottida's Avatar
The parts breakout for a 99 SC2 indicates that the seat foam was specific to the 97-2002 model year coupes (SC1 and SC2) and was not the same as the sedan. It does note that the passenger and drivers side uses the same part number. I imagine that is the case for the sedan as well. If you can find a Gen1 SL2 you can take the cushion from the passenger seat which will have less usage.
Pad - GM (21303018)
2001 SL1 MT (428,500 km @ 01/2019)
1999 SL2 MT (272,500 km @ 01/2019)
2011 Suburban LT (120,506 km @ 01/2019)
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 01-10-2019, 10:28 AM   #8
Hello all,
You can slide something firm between the foam and the support wires /springs to firm up the seat. You can also add additional foam, but use something high density / firm.
http://www.saturnfans.com/forums/sho...d.php?t=184156
^ ^^ You don't actually need to remove the whole seat to do it, but I thought it was easier that way. If you undo the plastic J hooks, you can lift the seat cover enough to raise the foam bottom and slip stuff in.
trottida and I posted a series of pics showing the differences in the seat foam bottom, link below.
I can't speak for all year SC2s, but the coupe seats have a "notch" in the foam at the front corners and putting my SL2 cover over it left a saggy part in the corner - see pic 7
http://www.saturnfans.com/forums/showthread.php?t=71607
Old 01-11-2019, 11:55 AM   #9
cpy911
cpy911 has a spectacular aura aboutcpy911 has a spectacular aura aboutcpy911 has a spectacular aura about
1996 SC2
This. I used tempered hardboard trick noted by OldNuc. Works like a dream. Was having pain due to sagging and one broken wire. This fixed it all
up nicely.
Add to cpy911's Reputation
Rate the quality of this post and help cpy911 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cpy911 is offline   Reply With Quote
Old 01-11-2019, 03:00 PM   #10
cgg17
cgg17's Avatar
1995 SL2
I know the seats from a gen 2 sedan and coupe are not the same, but it seems like the bases of the gen 1 sedan are similar to the gen 2 coupes. I think I will just go for it, after I do my clutch this weekend. I will post some pictures either later tonight or tomorrow to support my hunch...
I do believe that it is definitely not identical but it may work.
'08-09 Vue seat foam replacement? gm7 2008 Vue 0 10-18-2014 07:26 AM
Replacement Seat Foam? mfabel S-Series General 2 07-20-2006 10:41 AM
seat interchangability kirkm76 S-Series Mods 19 03-25-2006 01:27 AM
93 Sl2 driver seat foam Jim Waibel S-Series Tech 4 06-16-2004 10:13 PM
S series Seat interchangability? RBH S-Series Tech 5 12-02-2001 02:25 AM
