Old 01-10-2019, 08:58 PM   #1
Saturnl300 03
Saturnl300 03 is on a distinguished road
Default 03 l300 blower motor resistor
Does anyone know what's the correct blower motor resistor for a 03 l300? When I look it up it shows 2 one that looks like a motherboard and one that's like aluminum with vent slots.
Add to Saturnl300 03's Reputation
Rate the quality of this post and help Saturnl300 03 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturnl300 03 is offline   Reply With Quote
Old 01-10-2019, 10:12 PM   #2
02 LW300
02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough
02 LW300's Avatar
Default Re: 03 l300 blower motor resistor
It depends on what type of system your car has. Automatic temperature control has a digital display and you set the temp to heat and cool to. And basic Air has two knobs and a slide switch for the fan speed.
Add to 02 LW300's Reputation
Old 01-10-2019, 10:21 PM   #3
Saturnl300 03
I have automatic do you know what one it would be ?
Old 01-10-2019, 10:30 PM   #4
ssicarman
ssicarman's Avatar
A quick look on Rock Auto shows it pretty clear. They make the difference between the auto HVAC and manual systems resistors pretty clear.
Add to ssicarman's Reputation
Old 01-11-2019, 03:29 AM   #5
If you have auto climate control of hvac, dialing up and down temperature with the left knob as the digital display increments up or down and have the auto or manual fan speed on the right knob, you're probably using the side system blower speed controller. That's the expensive aluminum box with cooling fins. I replaced mine over a year ago. The plastic glove box must be removed, disconnecting the left inside lamp connector before carefully moving the glove box partially out . The body control module sits on top of this glove box and secured with two plastic snap fasteners inside the upper portion of the box. Releasing the two tabs allows sliding out the glove box while leaving the bcm inside the hole. Once out, a medium long Phillips screwdriver or torx bit loosens two screws to remove the solid state blower controller. I might have a thread in this forum about it, maybe a picture or two too.
Mine blew it's thermal fuse inside the controller when I disassembled it. Its on a shelf if I get around to searching for a replacement thermal fuse from electronic parts distributors. I'm not sure if that's all that failed as the replacement runs fine with the original blower motor.
Blower Motor and Resistor pithyapple S-Series Tech 10 11-04-2017 11:17 AM
Blower Motor Resistor? UsNsUbSoNaR S-Series Tech 21 10-31-2009 12:14 PM
03 Ion Blower Motor Resistor samnage Ion General 10 06-30-2009 08:17 PM
Blower resistor motor IrishDMBF Ion General 3 08-08-2007 12:12 AM
Blower Motor Resistor 92xjmuddin L-Series Tech 4 01-13-2006 08:39 AM
