Old 01-10-2019, 09:17 PM   #1
Joneswrld2
Joneswrld2 is on a distinguished road
2004 ION-3 Quad Coupe
Default 2004 Saturn Ion 3 blowing ignition fuse
I have a 2004 ion 3 and it keeps blowing the 10 amp ignition fuse under the hood. I replaced the ignition switch and no help. The engine will crank. Basically every time I turn the key to the run position the fuse immediately blows. Any thoughts on what my be wrong would be greatly appreciated.
Add to Joneswrld2's Reputation
Rate the quality of this post and help Joneswrld2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Joneswrld2 is offline   Reply With Quote
Old 01-11-2019, 12:01 AM   #2
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: 2004 Saturn Ion 3 blowing ignition fuse
That fuse provides power to the ignition module and the park/neutral safety switch if the car has an automatic transmission (or CVT).
I would unplug the ignition module and see if it happens again. I suspect something in the ignition module is shorting out when you turn the key on. If the fuse doesn't blow while the ignition module is unplugged, the ignition module may be bad. It is also possible that a break in the wire between the fuse block and the ignition module is causing a short so it wouldn't hurt to look for broken wires.
2007 Ion 2 Quad Coupe 5-speed manual 179K miles
2007 Chevy Equinox LT 190K miles
Add to ruley73's Reputation
1993 Saturn SC2 Ignition 2 30A blowing? HHx66 S-Series Tech 4 07-05-2016 02:05 PM
2008 Saturn Vue V6 3.6L Battery icon keeps coming on blowing key cap fuse Trifecta 2008 Vue 0 07-10-2015 08:25 PM
Saturn SL2 keeps blowing ignition fuse. mike2002 General Saturn Discussion 3 03-28-2015 07:35 PM
2004 3.5l vue - PARK fuse blowing jonolsonroll200 Vue Tech 1 05-28-2012 06:42 PM
fuse to 2003 saturn vue horn keeps blowing out aat1982 Vue Tech 10 12-17-2006 11:58 AM
