Old 01-09-2019, 02:30 AM   #1
kewlpop
kewlpop is on a distinguished road
1995 SL
Default 1995 S stock radio/cassette has no display, no reception.
1995 Saturn S, ~190,000, and #2 cylinder so fouled up i'm about to give up on the car, but that's another issue.
what i've got going on right now is the stock radio has no led display, no clock, no stations, just a blank display screen with the yellowish backlight.
buttons not working.
but....
i do hear slight static coming from the speakers. albeit with the volume control knob at max.
within the last two weeks the radio has actually cut off with same symptoms temporarily, but came back to life.
now it seems to be permanently dead.
one interesting observation is that when the radio shut off and came back on, the clock would reset to 1:00.
my car battery is probably in need of a replacement, but i have been able to give it a good charge using a reliable ol' skool trickle battery charger.
any chance this could be causing the radio symptom, or just coincidence?
thanks!
Add to kewlpop's Reputation
Rate the quality of this post and help kewlpop reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kewlpop is offline   Reply With Quote
Old 01-09-2019, 10:13 AM   #2
trottida
trottida's Avatar
Default Re: 1995 S stock radio/cassette has no display, no reception.
The clock reset would indicate it lost power. Based on the sound I would say it is something internal within the radio. They are cheap to buy used so I wouldn't even consider trying to fix it.
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 01-09-2019, 10:39 AM   #3
kewlpop
1995 SL
i am also guessing most likely it is hardware radio failure, and won't bother with any troubleshooting of possible breaks in connection along the electrical pathway.
unless someone else has other suggestions, i will go on the hunt for a new system.
i'm a very practical kind of person, on a low budget. what are some good replacements?
the cassette deck gave up the ghost well over a decade ago.
Old 01-09-2019, 10:46 AM   #4
They're cheap to buy when they're useless piles of electronics, once someone add's a useful aux port (that cost's $0.30, and maybe an hour to install) to it the price jumps from $30 to $300.
'95-'99 will swap right in. <THIS> is probably your best bet on eBay right now, there's no 2nd gen CD players and the higher priced tape w/EQ unit doesn't even have all the knobs (easy to swap if you have the same style unit, I believe Saturn/GM put different size knobs on each style unit).
They're pretty generic Delco units so if you have soldering experience/ability it should be fairly simple to open up and fix using various GM radio repair guides.
If you start looking at the $100 price level of used OEM radio's, I'd STRONGLY suggest looking at aftermarket radios as well. They offer so many more features in the same or smaller package it's crazy to stay with OEM unless you just require the fully stock look.
Old 01-09-2019, 11:01 AM   #5
kewlpop
1995 SL
thanks for the info fetch. exactly the type of advice i need.
for some reason i am actually leaning to keep the stock look.
i'm not too fancy, and don't require access to my spotify account while on the road. (i have no spotfiy acct.)
mainly, i just need a basic working FM reception to keep me grounded, and not necessarily for the tunes.
not to get too personal, but i need to recharge on a daily basis by listening to some good bible teaching. lots of great stations to choose from where i live.
Old 01-09-2019, 12:44 PM   #6
I currently have an XO vision XD-103 in my car. It's available on Amazon for $15, might be cheaper elsewhere. I wrote a review on here somewhere, biggest thing is that the clock does not stay on top, and when turned off it is completely black (no clock). Next is that it forgets I set it for random music after it is powered off.
I think FM was decent but don't really listen to radio
edit: review
http://www.saturnfans.com/forums/sho...d.php?t=186377
Best thing is that I have an old 8gb SD card in there loaded with about 3~4 hours of music and there is room for plenty more
There is a similar cheap unit on ebay right now for about $15~17 that looks like the clock might stay on top that I will be getting soon. The downside is that these require adapters and such, about $20 additional last I checked. Brings the net price to $35~45
Old 01-09-2019, 01:51 PM   #7
trottida
trottida's Avatar
edit: review
I noticed the O vision XD-107 is available on Amazon for about the same price and it has Bluetooth connectivity as well.
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 01-09-2019, 04:06 PM   #8
Ugh, I posted the wrong link. Thanks for mentioning the XD107
I mentioned the XD107 in my review here (currently $16 at the Walmart site - may allow for free instore pickup depending on location)
http://www.saturnfans.com/forums/sho....php?p=2230306
and some buyers mentioned it also comes with a remote control
The "no clock on top" thing is annoying enough that I am looking for a replacement unit. I emailed their support and they confirmed that there is no way to keep the clock on top.
I'm going to buy the ebay unit I mentioned in a month or two and post a review after. The other thing is that my instrument panel gauges are red now and the stereo LEDs are blue. Minor, but I would like them to match
1995 SL1 cassette player won't accept cassette offnr S-Series Tech 7 09-04-2013 11:26 AM
S-1995 sw2 stock radio Tape/am/fm tuner Keachj06 Classifieds 0 06-03-2006 02:34 AM
Free '97 Stock Radio AM/FM Cassette Red97Wagon Classifieds 1 08-01-2005 11:51 PM
Free '97 Stock Radio AM/FM Cassette Red97Wagon Classifieds 0 08-01-2005 11:46 PM
AM/FM cassette for 1995 SL2.. whitesl2 Classifieds 2 08-18-2002 03:44 PM
