Old 01-07-2019, 06:29 PM   #1
blueknigh7
blueknigh7 has a spectacular aura aboutblueknigh7 has a spectacular aura about
1997 SC2
Default Fuel Filter - Preventative or Wait?
Looking at the things to keep the satty running as long as possible...
I've never replaced the fuel filter, and it cranks on the 1st or 2nd turn usually. I found a really old thread that says it's recommended as much shorter intervals, but I bought it at 98k miles and now just passed 275k.
Should I wait till I start seeing symptoms? Or replace it when I have the chance at garage time? ('97 SC2)
Add to blueknigh7's Reputation
Rate the quality of this post and help blueknigh7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blueknigh7 is offline   Reply With Quote
Old 01-07-2019, 06:49 PM   #2
Zeebins
Zeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to all
Zeebins's Avatar
Default Re: Fuel Filter - Preventative or Wait?
With almost 200K on one filter, I'd change it. I don't remember exactly what the recommended OE interval was for changing it but I'm pretty sure it was under 100K.
It won't help your problem with having to turn the key twice to start the car but a clean filter will be a lot easier on the fuel pump.
Road salt will be the death of me
1997 SL2, 112K miles
Add to Zeebins's Reputation
Old 01-07-2019, 07:24 PM   #3
cgg17
cgg17 will become famous soon enoughcgg17 will become famous soon enough
cgg17's Avatar
I would replace it. I have yet to do mine as well. I think it is best to be safe than sorry.
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Old 01-07-2019, 07:46 PM   #4
The 97 and older is a 60,000 mile replace interval and they last considerably longer but, they also end up stuck in the piping if not changed periodically if the design is not corrosion proof.
Old 01-08-2019, 09:50 AM   #5
You know, I've never had a problem that I could trace to a fuel filter, and I've only replaced fuel filters as preventative maintenance on a few cars.
That said, I'd replace the filter just because you have at least 177k on the old one, which is about 3 x the recommended interval. You got your money's worth out of the old one
Old 01-08-2019, 01:05 PM   #6
blueknigh7
1997 SC2
Thanks for the replies! The satty actually starts on the first keyturn - I was referring to the 2nd turnover of the engine - which I think is still pretty good?
Any particular part or brand recommended? On Rockauto, I see hastings, acdelco, and Bosch. I also see Wix at my local Oreily's.
EDIT: Actually, found the WIX also at Rockauto - wasn't shown under the car listing itself, but you can manually find it under part #Wix 33575
Thanks!
Old 01-08-2019, 01:21 PM   #7
http://www.saturnfans.com/forums/sho...uel+filter+mod
Originally Posted by DIYguy
OK, so you are bored on a rainy day and are about due for a fuel filter change anyway.
Feel like spending $30-$40 (or more) on another filter-hose-Fitting-hose-slip fitting assembly and adding the old one to a local landfill?
I thought not, neither did I.
Old 01-08-2019, 01:24 PM   #8
Yes, that is very good
Zeebins was talking about the well known issue that only affects 1997 models - fuel pressure decays quickly, so owners need to turn the key several times (while pressure builds) or turn the key to ON, wait a few seconds for pressure to build, then turn the key to START
Sounds like you have been lucky so far in that regard, or you or PO changed the fuel pump
Old 01-08-2019, 01:53 PM   #9
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
On Rock Auto, look under 1997 SC1, I see six listed...
Mobil 1 ESP 0W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 01-08-2019, 02:01 PM   #10
trottida
trottida's Avatar
The Wix brand is the recommended filter but I think that is 98+ where the regulator is built in.
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 01-08-2019, 03:58 PM   #11
blueknigh7
1997 SC2
There was a recall on the '97 fuel pump and that was changed out before I took ownership, but nothing's been done since. Count my lucky stars.
If you look under SC1, you'll see the Wix, but if you look under SC2, it doesn't show as a part. Weird.
Old 01-08-2019, 04:07 PM   #12
Zeebins
Zeebins's Avatar
When I did my fuel filter, I bought the Hastings one and I haven't had any problems with it. The 17 year old one I took out was a Fram filter though and that was the cheapest option listed on rock auto. (Or it was, doesn't seem to be there any more.) 97 and below doesn't seem to really care about what filter you put in, even if it's some cheap one.
Old 01-08-2019, 06:05 PM   #13
W1PIT
W1PIT will become famous soon enough
1996 SL2
2001 SL2
I changed the fuel filter on my 96 sl2 at 220,000 for something to do......., and still running the stock fuel pump at 270, 000 + go for it, its not hard to do.
96 SL2 268k miles .2001 SL2 sold. 2000 CRV 345,600 miles (my Wife's Beast)
Add to W1PIT's Reputation
Rate the quality of this post and help W1PIT reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
W1PIT is offline   Reply With Quote
New fuel pump/filter no pressure out filter????? Justross1979 General Saturn Discussion 14 06-11-2017 01:11 PM
Parts Master fuel filter vs Wix fuel filter AprilSL1 S-Series Tech 21 08-05-2014 09:43 PM
smells like fuel vapors under hood of 93 SL2. Cheap fram plastic fuel filter? 2003MercMaraude S-Series Tech 2 10-17-2008 07:29 AM
Fuel Pump replacement 96SL2 @ 95k miles for preventative maintenance? LATECH425 S-Series General 8 02-13-2006 11:51 AM
Fuel injector? Fuel filter? Air filter? LoveMySaturn Miscellaneous Tech 13 05-14-2004 10:14 PM
