Old 12-06-2014, 05:32 PM   #1
L300v6
L300v6 is on a distinguished road
L300v6's Avatar
Default 2001 Saturn L300 - Steering issues
Hello Saturn enthusiasts,
While backing out of the driveway turning left, the steering wheel seemed to have way more play than usual. Normally it is much stiffer, but it became loose and I had to spin the wheel way more than often to get it to do what I wanted.
I do know that the stabilizer linkage is separated on the passenger side.
Any help much appreciated,
Thanks
Add to L300v6's Reputation
Rate the quality of this post and help L300v6 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L300v6 is offline   Reply With Quote
Old 12-06-2014, 05:46 PM   #2
L300v6
L300v6's Avatar
Default Re: 2001 Saturn L300 - Steering issues
There is also a thumping sound while turning the wheel to a certain degree.
Old 12-06-2014, 05:59 PM   #3
L300v6
L300v6's Avatar
One thing to note, it is tight and randomly I will get excessive play. It will be tight then loose then tight then loose.
Old 12-06-2014, 09:40 PM   #4
L300v6
L300v6's Avatar
Power steering fluid is clean with no metal shavings, it's filled up. I rocked the driver and passenger wheels on the left and right axis, where I noticed a loud clunk (Both sides made the noise). Further test driving the passenger wheel was not in line with the driver, it was also rubbing on the wheel well.
Old 12-07-2014, 06:33 AM   #5
Mileage, parts replaced? Worn tie rods?
Old 12-07-2014, 11:29 PM   #6
Russet
2002 L-Series 3.0L Sedan
This noise is usually a indication of bad axle boot and you need to replair the axle with the torn boot on it. You have to lift the front up and look at the wheel well to see if it is the right or left shaft that has a broken boot. Normal straight driving you will not notice the sound til you start turning more to one side or the other.
Add to Russet's Reputation
Old 12-10-2014, 02:56 AM   #7
L300v6
L300v6's Avatar
So the frame was completely rusted through, I got it on a lift and I'm not sure it's even repairable.. Seems like too much work for what the car is worth.
Old 12-16-2014, 10:48 PM   #8
born again
born again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of light
2000 L-Series 2.2L Wagon
His subframe is rotted out. The control arms can flap around because they are attached to it. If it is really bad the half shafts can pull out of the transmission. Been there, etc. The fix is to go to car-part.com and find a replacement. I paid about $300 for the frame and a bit more to install and align. Be prepared to get some weld repairs done to the replacement frame.
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-16-2014, 11:24 PM   #9
pierrot
pierrot's Avatar
born again's idea is a good one. If you look around at Car-Part.com you can find these parts in various places across the USA. If I were you, I'd attempt to purchase one from a dry climate state in the Southwest or Pacific region, more specifically, Southern California since the climate is dryer here than in NorCal. Nevertheless, there are some very good prices for this item referred to here as the "engine cradle." Even with shipping charges it's conceivable that you could find one for less than $300.00 altogether and probably rust free as well. (The parts page link below assumes your car has an automatic transmission.)
If it's still worth it to you to hang on to the car for some time longer then don't give up on it just yet. You're not out of options.
http://www.car-part.com/cgi-bin/sear...ey=&userPage=1
288,000 miles-it keeps on rolling!
Add to pierrot's Reputation
2001 L300 starting issues please help!! Jcs89702 L-Series Tech 23 06-19-2013 12:10 PM
2001 Saturn L300 - Having Issues, please help... TDFDiesel L-Series Tech 3 10-28-2012 03:05 PM
2001 L300 with MAF issues hypnotize83 L-Series Tech 12 08-15-2012 04:06 PM
03 L300 Steering Column Issues SACTOWNMOM L-Series Tech 7 11-04-2010 10:44 AM
2001 L300 Issues (BCM I think) - HELP!! robertweston L-Series Tech 3 09-02-2008 10:02 PM
