Old 05-29-2009, 09:07 PM   #1
LelandC
LelandC is on a distinguished road
Default Replacing front turn signal?
Is it easy to change the front turn signal on an 08 Aura? Our's is burned out. I only took a quick glance at it but it seems a lot different than our previous Ion.
-Leland
Add to LelandC's Reputation
Rate the quality of this post and help LelandC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LelandC is offline   Reply With Quote
Old 05-29-2009, 11:17 PM   #2
Phaeton Driver
Phaeton Driver will become famous soon enough
2007 AURA XR
Default Re: Replacing front turn signal?
-Leland
I suspect it will take the same procedure as to change the low beam/high beam lamps.
Several threads here have outlined it but basically you have to remove part of the inner fender liner and loosen the front bumper/cover to get at the headlamp assembly. If not the entire procedure, at least the inner fender liner will have to come partially out.
Maybe someone here has done it but never posted how they did it?
You can try the search feature too.
Add to Phaeton Driver's Reputation
Rate the quality of this post and help Phaeton Driver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Phaeton Driver is offline   Reply With Quote
Old 05-30-2009, 05:48 PM   #3
3 Rings
3 Rings is on a distinguished road
3 Rings's Avatar
2008 AURA XR
2007 SKY Red Line
If you have less than 3 years or 36,000 miles on the car, then it can be replaced under the bumper-to-bumper warranty by the dealer.
Add to 3 Rings's Reputation
Rate the quality of this post and help 3 Rings reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
3 Rings is offline   Reply With Quote
Old 05-30-2009, 11:48 PM   #4
gregh2000
gregh2000 has a spectacular aura aboutgregh2000 has a spectacular aura about
2007 AURA XR
You might want to check and see if you can get it out without taking the housing off. You might be able to squeak out the turn signal bulb without removing the whole housing.
Add to gregh2000's Reputation
Rate the quality of this post and help gregh2000 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gregh2000 is offline   Reply With Quote
Turn signal in front bumper blen_to Astra General 6 01-25-2010 04:06 PM
Front Turn Signal Lenes DrPimper S-Series General 1 10-09-2007 12:34 AM
Replacing In-Dash Turn Signal Indicator Bulb geeminator S-Series Tech 2 01-28-2007 07:48 PM
Front Turn Signal Bulb ygor Relay Tech 2 01-24-2007 12:28 AM
Replacing the daytime running light/turn signal bulb Crawdaddy Ion General 7 10-29-2005 08:38 PM
