Old 04-28-2009, 07:34 PM   #1
ppeSC2
ppeSC2 is on a distinguished road
Default Power Steering Pump
I have a 1996 SC2 and my powersteering pump pulley went out yesterday. The bearings got so hot it rounded out the pulley. I was wondering if my pump is still good. The bearing is still on the pump and it turns with ease. I am confused because about an hour earlier of this happening i started to lose powersteering, so i added some fluid and it seemed to clear up. So is there anything i should check for or look for to see if my pump is still good. And i know there is probably a thread about this somewhere but i tryed to search it and it didnt work. Thank You
Real Cars dont make power to the front tires, they lift them
When the clutch drops the f*^cking stops
When the green light drops the Bull S^&t Stops
96 SC2 1.9 DOHC 5 Speed
Add to ppeSC2's Reputation
Rate the quality of this post and help ppeSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ppeSC2 is offline   Reply With Quote
Old 04-28-2009, 08:20 PM   #2
BlackPlastic
BlackPlastic is on a distinguished road
Default Re: Power Steering Pump
I've seen that before, but it was because the pump had no fluid, and it basically seized up and the pulley stripped right off the splines. You might be better off just finding a new pump at the junkyard, because it might cost less than a new pulley. Maybe, idk.
Add to BlackPlastic's Reputation
Rate the quality of this post and help BlackPlastic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BlackPlastic is offline   Reply With Quote
Old 04-28-2009, 08:32 PM   #3
Squareback
Squareback's Avatar
2005 ION-2 Sedan
I would replace the pump with a good used one.
Certified Saturn Technician
Old 04-29-2009, 03:31 PM   #4
ppeSC2
Last month i replaced my tensioner pulley, and it was completley shot, i talked to a few people and they said because it was not used to the belt being on so tight that it wore out the bearings, but i dont know if i believe that or not. I think i am just gonna go to the junkyard and get a good used one.
power steering pump MikeNW S-Series General 11 08-27-2009 05:38 PM
Power Steering pump going Ls1Junky S-Series Tech 7 04-09-2008 10:56 PM
Power Steering Pump riggs S-Series Tech 0 01-07-2007 09:35 PM
Need quick help - replacing power steering pump and water pump on V6Ö. Emanresu2 L-Series General 6 05-18-2006 05:38 PM
Power Steering Pump? sc2_94 S-Series Tech 7 10-27-2001 12:05 PM
