Old 09-02-2000, 04:19 PM   #1
VTHokie00SL2
VTHokie00SL2 will become famous soon enoughVTHokie00SL2 will become famous soon enough
VTHokie00SL2's Avatar
Default Steering pump leaking
When I brought my car in for an oil change today I found out that the steering pump is leaking onto the alternator. They tell me I could probably wait until my next service to get it fixed, but it sounds like something that should be dealt with quickly. Has anyone else out there had to get this repair?
Add to VTHokie00SL2's Reputation
Rate the quality of this post and help VTHokie00SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VTHokie00SL2 is offline
Old 09-02-2000, 09:53 PM   #2
100KSW2
100KSW2 is on a distinguished road
100KSW2's Avatar
Default
I think there were some threads about this earlier this year (try a search?).
My car has a leak around the boot on the steering rack. I get a low whine at parking speed once in a while, but other than watching the level of the power steering fluid (I added about 1-2 onces last year when it first happened) I have not had to do anything else so far. If I have to replace the rack it is about a $700-800 repair including parts and allignment. Good luck.
Add to 100KSW2's Reputation
Rate the quality of this post and help 100KSW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
100KSW2 is offline
Old 09-06-2000, 11:18 AM   #3
jeff92sl2
Guest
Posts: n/a
Default
I had the same problem about three years ago. I tried to remove the pump, but could get one last hose connection loose, even with hose wrenches. Ended up having the car towed to my not very favorite dealer. I think the replacement was about $250 to $300. I tried the job myself because a non-Saturn pump would have been quite a bit cheaper.
Jeff
Add to jeff92sl2's Reputation
Rate the quality of this post and help jeff92sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-06-2000, 09:37 PM   #4
BILL
BILL is on a distinguished road
Default
IT SOUNDS LIKE YOU HAVE A FRONT PUMP SEAL LEAKING. IF THE LEAK IS NOT TOO BAD YOU CAN REPLACE JUST THE SHAFT SEAL WHICH IS ABOUT A 3.00 PART LABOR IS ABOUT 130.00. THE SEAL CAN BE REMOVED WITH A SCREW DRIVER BUT THE PULLEY NEEDS SPECIAL TOOLS FOR EASY R&R.
Add to BILL's Reputation
Rate the quality of this post and help BILL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BILL is offline
Old 09-07-2000, 09:39 AM   #5
VTHokie00SL2
Default
I had the car looked at yesterday. I was informed that the cam cover gasket was leaking, so I had that fixed (~ $120), and I was told that it's possible that this was the only problem and the steering pump isn't actually leaking. They told me to bring the car back in a few weeks to see if the steering pump is really leaking (they put a dye in the fuid). Hopefully it is just a seal, if there's still a problem at all...
water pump leaking bdokeefe S-Series Tech 5 05-27-2008 08:35 AM
Need quick help - replacing power steering pump and water pump on V6Ö. Emanresu2 L-Series General 6 05-18-2006 05:38 PM
power steering leaking, and faulty fuel pump? fetchitfido S-Series Tech 15 05-08-2006 09:57 PM
Leaking Water Pump edlee S-Series General 7 12-11-2005 09:23 AM
Has anyone had a prob with a leaking power steering pump on the v6 Saturn 6 L-Series General 2 03-29-2005 10:56 PM
