Old 08-02-2007, 11:25 AM   #1
SVO4Turbo
SVO4Turbo is on a distinguished road
Default Dies at Idle with No AC / Idles 400 RPM with AC. Runs Fine
Hi all. My satty runs really good. Just recently started giving me problems with idling. The car runs great otherwise, just doesn't want to idle. Ideas?
1995 SL2 - 143K
Add to SVO4Turbo's Reputation
Rate the quality of this post and help SVO4Turbo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SVO4Turbo is offline   Reply With Quote
Old 08-02-2007, 11:39 AM   #2
Greg1
Greg1's Avatar
1997 SW2
Default Re: Dies at Idle with No AC / Idles 400 RPM with AC. Runs Fine
There is a valve on the throttle body which maintains idle speed. Idle Air Control valve. On my 97 it was dirty which caused unstable idling. I've had no problems after cleaning it and the throttle body. I chose to remove them for the cleaning.
97 SW2 5-Sp 273k -mine
Add to Greg1's Reputation
Rate the quality of this post and help Greg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-02-2007, 03:58 PM   #3
In addition to the above I would suggest if your normal cold start doesn't idle at 1200 rpm then gradually return to 800-900 rpm when warm you may have the infamous engine coolant temperature sensor problem (ECTS). The How-to Tips library's first two posts covers everything including the two-wire connector and pictures of the original plastic sensor compared to the permanent brass replacement.
Old 08-02-2007, 04:21 PM   #4
Luke
Luke's Avatar
Default
There is what is called an Idle control valve. This will 'gum' up over time, which will initially show up when you come to a stop, with the engine's idle dropping to below 750 rpms, usually returning to an appropriate idle.
Add to Luke's Reputation
Luke is offline   Reply With Quote
Old 08-02-2007, 04:41 PM   #5
SVO4Turbo
Yes, this is pretty much what will happen. As I come to a stop, it will dip way down, but then it will return closer to normal. It's just to the point now, if the AC is off, it dips low enough to die, but will immediately restart just fine.
1995 SL2 - 143K
Old 08-02-2007, 04:54 PM   #6
Another clue, AFAIK, that it's the IAC. The PCM pulls the IAC open a scoshe more when the A/C is on; in your case, it's probably just enough to stave off the stall.
Add to madpogue's Reputation
Old 08-02-2007, 05:00 PM   #7
SVO4Turbo
So where do I find the IAC valve? Can I clean it with gumout or something similar or should I just get a new one?
1995 SL2 - 143K
Old 08-02-2007, 05:47 PM   #8
The throttle body will have the iacv and the tps so removal of the throttle body may be easier to access everything. I believe disconnecting the two plugs and nuts/bolts will be all that's needed to take it off the car. The tps is on one side of the throttle plate shaft while the iacv is the other electrical item that controls a bypass air port. The recommended cleaner is electrical contact cleaner since there are a pair of precision servo stepper motors and potentiometer that serves as a feedback position sensor for the ECM/PCM.
Old 08-03-2007, 10:23 AM   #9
Luke
Luke's Avatar
Fm > SVO 4 Turbo
At least, in my case, it was a classic case of the IAC valve gumming up.
As a matter of fact, I use those conditions as an alert that my IAC valve is due to be cleaned or replaced.
Old 08-03-2007, 06:13 PM   #10
TwinRevver
TwinRevver is on a distinguished road
Oh my sl2, cold start revved to 2k then down quickly to 1.5k then to 1k until 1/4 way warmed up. Is this normal??
Add to TwinRevver's Reputation
Rate the quality of this post and help TwinRevver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TwinRevver is offline   Reply With Quote
Old 08-04-2007, 12:13 PM   #11
Luke
Luke's Avatar
My cold start results in a 12,500 rpms, until the coolant temperature notes that the coolant is beginning to warm up, at which time, the rpms drop down to about 1,100 rpms. It is at this point, I'll begin to leave the garage. This time cycle is usually within 2-3 minutes.
After driving for about 10 minutes, the rpms will settle at 725 / 750 rpms.
After driving for about 20 - 30 minutes, with the engine being complete warmed up and running at a constant / settled operating temperature, the rpms will settle at 700.
Any change in that setup, for me, I'd take notice.
car idles high, 2000 rpm idle pimpin88 S-Series Tech 7 12-11-2009 05:49 PM
Idles fine, but starves for gas (2002 SL1) x-angel S-Series Tech 33 11-27-2009 10:07 PM
Vue idles fine, runs terrible, like a bucking BRONCO live2beotch Vue General 7 02-23-2007 04:17 PM
98 SC2 idles funny, dies, oil in spark plug well, fixed that, still dies, etc. Kpendrgn S-Series Tech 18 02-03-2007 09:58 PM
Idles fine with AC on, low Idle with AC off wvman L-Series Tech 0 07-30-2006 08:16 PM
