Old 11-22-2019, 01:50 PM   #1
RobertGary1
1996 SC2
Default Fuel pump Delphi vs Spectra
I've had my Delphi pump assembly for 6 months now and its not impressive. Now its indicating full fuel down to the first 1/2 of the tank and its leaking down immediately. If I plug the rail I see the pump pressure drop off to zero within a second of the pump shutting off. It makes starting annoying.
I know there are a lot of bad quality pumps out there and I really don't want to get stranded 100 miles from home so I'm looking for a quality pump. I"ve had good luck with Delphi's in the past.
So should I roll the dice on another Delphi or go with the Spectra. I see Spectra is a favorite on Rockauto.
-Robert
Old 11-22-2019, 04:57 PM   #2
hholbein
1997 SW2
Default Re: Fuel pump Delphi vs Spectra
I'd review old threads here for advice on brands. I seem to recall that Carter and/or Airtex were the preferred brands for reliable/properly inspected fuel pumps.
On other parts like radiator replacements, Spectra's reputation has been mixed. And Delphi has been eroding its reputation as a lowest-bid part reboxer.
Add to hholbein's Reputation
Old 11-22-2019, 06:25 PM   #3
Carter ONLY, avoid all the rest -- junk
Old 11-24-2019, 01:35 PM   #4
hholbein
1997 SW2
Thanks, OldNuc! Redoing a fuel pump because of crappy replacement parts would have to be one of the worst!
Old 12-10-2019, 12:13 PM   #5
RobertGary1
1996 SC2
Put the Carter in this weekend. Issues seem to be resolved. Car starts up right away after sitting. Of course the Delphi pump worked well for 6 months too though. I did notice that the Carter pump makes more noise than the Delphi but you can't hear it once the car is running.
-Robert
TYC or Spectra radiator cityhawk L-Series Tech 4 01-16-2015 03:02 PM
Fuel Pump Troubleshooting results. Bad pump? saladdin S-Series Tech 13 02-14-2013 10:39 AM
spectra cold air kit sl2owner80 S-Series Mods 3 08-17-2012 02:45 PM
Delphi or Silla water pump???? rich_d S-Series Tech 40 02-23-2012 10:52 PM
Fuel Pump 2011: PT3 - Bosch Fuel Sending Unit Part Number? x-angel S-Series Tech 4 03-23-2011 12:34 PM
