Old 11-15-2006, 07:48 PM   #1
Bedlam
Bedlam is on a distinguished road
Default Rattle in front strut/shcok area of 2006 Vue
Has anyone experienced a rattle in the front strut/shock area? I have a noise that I can't recreate when Ihave the Vue in for service. My warranty runs out in 200 miles and I do not know what to do. Help.
Add to Bedlam's Reputation
Rate the quality of this post and help Bedlam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bedlam is offline   Reply With Quote
Old 11-15-2006, 10:53 PM   #2
sspeer
sspeer is on a distinguished road
sspeer's Avatar
Default Re: Rattle in front strut/shcok area of 2006 Vue
It's fairly common..I need to take mine in.. the right front strut makes a nasty creak and some sloppy rattling noises over speed bumps
Add to sspeer's Reputation
Rate the quality of this post and help sspeer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sspeer is offline   Reply With Quote
Old 11-16-2006, 09:35 AM   #3
Ritz
Ritz's Avatar
I was under the impression that this issue had been "dealt with" on '06+ VUEs. No?
Add to Ritz's Reputation
Rate the quality of this post and help Ritz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-16-2006, 10:32 AM   #4
sspeer
sspeer's Avatar
I'm not sure. I haven't heard anything about it, but I wasn't really looking for info.
I'm not exactly sure what the source of the problem is to begin with. If it is due to the suspension design or if it was a supplier issue.
Old 11-16-2006, 05:21 PM   #5
1saxman
Make them check the sway bar end links for play and brake calipers for looseness. When driving slowly over uneven surfaces the sway bar ends will rattle. During the rattle, lightly apply the service brake to see if the rattle can turned off with the brake. If so, it's the calipers. There's no guarantee that it couldn't be both at the same time.
Add to 1saxman's Reputation
Old 11-16-2006, 05:25 PM   #6
Ollie
Ollie will become famous soon enough
Ollie's Avatar
I just had my right front strut and strut mount replaced two-three weeks ago because of the same reason. Under warranty and it took about an hour and a half. 05' VUE though...
"I won't be wronged, I won't be insulted, and I won't be laid a hand on. I don't do these things to other people and I expect the same from them."
-John Wayne-
Add to Ollie's Reputation
Rate the quality of this post and help Ollie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ollie is offline   Reply With Quote
Old 11-16-2006, 09:20 PM   #7
YIN
YIN is on a distinguished road
YIN's Avatar
I just started getting the same problem. 4500 miles
07 Grand Prix GT s/c
Add to YIN's Reputation
Rate the quality of this post and help YIN reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
YIN is offline   Reply With Quote
Old 11-17-2006, 09:28 AM   #8
Bedlam
Thanks everyone,
I got to the dealer with 30 miles remaining on my warranty. I was able to recreate the sound with them in the car. I will now be able to get it repaired under warranty at a later date. I will post the results to help anyone else who might be having the same problem. Thanks for all the help.
Old 11-17-2006, 09:44 AM   #9
Web Raven
Web Raven is on a distinguished road
Web Raven's Avatar
I have an 06 AWD Vue and this is exactly the issue I was having. They initially thought it was the suspension, but after removing the sway bar and driving it, discovered it was the guide pin in the caliper on the front passenger side.
Add to Web Raven's Reputation
Rate the quality of this post and help Web Raven reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Web Raven is offline   Reply With Quote
Old 11-17-2006, 09:46 AM   #10
Web Raven
Web Raven's Avatar
Originally Posted by Bedlam
Thanks everyone,
Wow... you have an 06 Vue and have already run out your warranty? And I thought that *I* did a lot of driving!
Old 11-18-2006, 01:39 AM   #11
mikebutkus
mikebutkus is on a distinguished road
Check the front lower control arm bushing. The one bolted to the frame. Round rubber bushing holding the back of the lower A arm in place. The rubber in the bushing should keep the arm in the center of the bushing.
Mine rattled on uneven surfaces. About $109 for the dealer to replace. They didn't do a alignment so it's just a unbolt and bolt thing. Big bolts though !
Add to mikebutkus's Reputation
Rate the quality of this post and help mikebutkus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mikebutkus is offline   Reply With Quote
Old 11-18-2006, 08:59 AM   #12
kfraney
kfraney is on a distinguished road
kfraney's Avatar
2004 VUE 3.5L
I'm in New Jersey too. What dealer did the service?
Add to kfraney's Reputation
Rate the quality of this post and help kfraney reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kfraney is offline   Reply With Quote
Old 11-18-2006, 10:56 AM   #13
mikec
mikec will become famous soon enough
mikec's Avatar
I have this same problem myself. I think it's something in the front brakes. They are next on my never ending list of Vue repairs so I will report back when I get them replaced.
Add to mikec's Reputation
Rate the quality of this post and help mikec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mikec is offline   Reply With Quote
Old 11-20-2006, 12:17 PM   #14
tomvan72
tomvan72 is on a distinguished road
If the noise is coming from the right side it is probably the strut mount. There is a bearing in there and some of them go bad. I saw an 06 fwd v6 with 14k on it and it needed replacing. The owner of course drove the ***** out of it. Speaking with some of the Saturn Techs, the rplacements should be a longer lasting fix than some of the original mounts.
Add to tomvan72's Reputation
Rate the quality of this post and help tomvan72 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tomvan72 is offline   Reply With Quote
Old 11-20-2006, 07:06 PM   #15
sspeer
sspeer's Avatar
Is the right side different than the left? (besides the obvious things)
You make it sound as if there isn't a bearing on the left side..just curious because it's my right side that's squeaking
Old 11-20-2006, 07:14 PM   #16
WLKVUE
WLKVUE is on a distinguished road
I had the caliper pin bushings replaced at 25,000 miles on my 2006 VUE two weeks ago. Warranty work. Took a whole lot of rattle out of the front end. The rattle seemed to come mainly from the right side also.
Add to WLKVUE's Reputation
Rate the quality of this post and help WLKVUE reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WLKVUE is offline   Reply With Quote
Old 11-20-2006, 10:46 PM   #17
Web Raven
Web Raven's Avatar
I had that same thing done right around 26K and it got rid of the rattle going slowly over bumps, but now it seems to be back and coming more from the left side, but I'm not entirely sure.
I'm going on a road trip to Mississippi (from north of Chicago) to pick up a new puppy on December 1st... with the holiday, work, etc., I don't have time to bring this thing in for repairs. Do you guys think it'll survive the trip? *fingers crossed that it does*
Old 11-22-2006, 06:40 PM   #18
mikec
mikec's Avatar
By right side, do you mean front passenger side or front driver side?
Old 11-23-2006, 01:21 AM   #19
Web Raven
Web Raven's Avatar
Sorry... yeah, right side = front passenger side.
(Edit: Err, nevermind, you weren't talking to me. LOL Sometimes I read too quickly.)
Old 11-24-2006, 10:01 PM   #20
burgeke
burgeke is on a distinguished road
Someone earlier mentioned being in NJ. I had mine to Saturn of Rt 33 - 5 times before finally being fixed (right over the bridge in PA). It turned out to be something with the calipers (someone else here mentioned bushings so maybe that was it). I always heard it as coming from the right side. I repro'd with them in the car and they still couldn't fix until that last time.... it was like a breath of magic that all of a sudden they figured out what it was. Couldn't have been more frustrating......
Good luck
Add to burgeke's Reputation
Rate the quality of this post and help burgeke reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
burgeke is offline   Reply With Quote
2006 VUE Front Strut Replacement Procedure Needed tonyk96 Vue General 1 08-28-2009 03:50 PM
Front Strut Help. 2006 Vue qwikz28 Vue Tech 16 08-10-2009 01:44 AM
2006 Redline front strut/ rear shock replacement hein Vue Tech 2 11-06-2008 01:24 PM
2006 V6 vue front end rattle mehalski Vue Tech 6 08-27-2007 09:57 AM
2004 Vue Front End Rattle ibecruisin Vue General 3 04-14-2006 07:55 PM
