Old 01-11-2021, 03:49 AM   #1
meikees
meikees is on a distinguished road
2004 VUE 2.2L
Default Transmission/Clutch Questions
Hello I own a 2004 saturn vue 5 spd. I have owned it for 7 years never had any serious problems. UNTIL the clutch started losing pressure when exiting the highway. Had the master replaced and the transmission fluid changed. Now 2 weeks later its doing the samething, only this time when I pulled up to the stop sign on the off ramp and put it in first it got stuck. The clutch was very weak and only moved maybe a half an inch. I pulled over gave it 2-3 min then I pulled it out of first. Drove it no problems after. It drives like a dream in town no issues since the master and the transmission fluid have been changed. The only problem is the highway. Im hoping somebody here has some ideas. It is my first car and has served me well. I dont know if its something easy to fix or its time to say goodbye. 195k miles. I got it with 116k miles. Thanks for being here!
meikees is offline   Reply With Quote
Old 01-14-2021, 12:23 PM   #2
Bruce Rock
Bruce Rock is just really niceBruce Rock is just really niceBruce Rock is just really niceBruce Rock is just really nice
2000 SL2
2006 VUE 2.2L
Default Re: Transmission/Clutch Questions
What pressure is the clutch loosing? The spring pressure that engages the clutch to the flywheel or the hydraulic pressure that disengages the clutch from the flywheel?
How were you able to tell the clutch moved 1/2"? Did you mean the clutch pedal?
How is the hydraulic fluid level for the clutch?
Old 01-15-2021, 07:35 AM   #3
meikees
2004 VUE 2.2L
The clutch pedal looses pressure after riding on the highway, it only moved half an inch. The fluid level is good. I believe it to be the hydraulics, but I know nothing of cars. Research has come to the conclusion the slave might need replaced or its the inner workings of the transmission. Its just odd it works fine if in town, but once I get on the interstate for a short period it tends to act up. No shifting just riding in 5th.
Old 01-15-2021, 11:02 AM   #4
Bill Murray
Bill Murray is a jewel in the roughBill Murray is a jewel in the roughBill Murray is a jewel in the roughBill Murray is a jewel in the rough
2007 ION-2 Quad Coupe
1997 SC1
It is possible for the piston in the slave cylinder to leak (bypass fluid) without having an external leak. Assuming your replaced master cylinder is OK (lots of defective replacement parts on the market these days so you always have to be suspicious) and there's no external leak, maybe the slave cylinder is faulty.
Never worked on one of these but it appears it's the "concentric" unitized design slave cylinder / throwout bearing which means you have to remove the transmission to change it out. If you get to that point, it's worth it to remove the clutch assembly to take a look how much material is left on the friction disc.
Old 01-16-2021, 03:34 AM   #5
meikees
2004 VUE 2.2L
Good to know! Thanks for your replies!
Old 01-16-2021, 10:06 PM   #6
Bruce Rock
2000 SL2
2006 VUE 2.2L
What is stopping the clutch pedal from moving more than 1/2"?
Old 01-22-2021, 12:02 AM   #7
meikees
2004 VUE 2.2L
There was hardly any pressure which led it to not being able to move it more than a half an inch.
UPDATE....IT WAS THE SLAVE CYLINDER. Internal leak of the cylinder, no signs of leakage. Had it replaced, everything is working as it should. Thanks for your responses!
Clutch questions 08AstraOtt Astra General 5 08-02-2018 09:47 AM
Manual Transmission/Clutch/Crank Questions KevinVarnes Vue Tech 4 09-12-2014 02:20 AM
clutch story/questions Jeff F S-Series Tech 3 03-14-2014 09:10 AM
Clutch questions AstraLover Astra Tech 0 02-06-2013 01:13 AM
New clutch questions! mgordon1100 S-Series Tech 14 02-22-2008 02:04 AM
