Old 01-07-2021, 12:07 AM   #1
RobertGary1
RobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of light
Default Leak at tb axle
I was bored and decided to play around with my smoke machine. Pushing smoke through the pvc hose and plugging the tb intake I got some smoke from the case via blowby I suppose and a fair amount around the tb axle at the spring. Wasn’t expecting that. Don’t seem to have any drivability issues but was surprised.
Old 01-07-2021, 02:34 PM   #2
billr
Default Re: Leak at tb axle
Fortunately, this is an SD (speed-density) EFI, slight vacuum leaks don't matter at all; no MAF sensor to be being "cheated".
Old 01-08-2021, 09:21 AM   #3
Highmile
Highmile's Avatar
The only time the TB shaft is an issue is when it becomes so worn the throttle plate doesn't close consistently.
Highmile
'95 SL1 722k and counting
Old 01-10-2021, 01:44 PM   #4
bumpdraft
bumpdraft's Avatar
1998 SW2
Highmile
Spray some chain lube and the vacuum will suck it past the ball bearing and flush out some of the road grit, extending the life of the bearing.
Old 01-17-2021, 02:52 AM   #5
TomM96
Good thinking, Bumpdraft !
Old 01-17-2021, 03:17 PM   #6
bumpdraft
bumpdraft's Avatar
1998 SW2
Your welcome
I was thinking...be careful the lube does not contain anything that would harm the oxygen sensor.
I was over-thinking...the TB butterfly return spring is strong. As a sort of an air filter, you might be able to wrap some oiled, thin felt cloth around the outside of the spring and staple the felt to itself. It would be best to remove the TB to wrap the felt and to verify that nothing dangerous would happen. Be careful.
Old 01-25-2021, 10:51 AM   #7
Highmile
Highmile's Avatar
The number of miles it took mine to wear out is well beyond what most will every see. Simply replaced with a low mile used unit. I want to say that it was well into the 500,000 mile range but my memory isn't as good as it used to be.
Highmile
'95 SL1 723k and counting
Old 01-25-2021, 11:22 AM   #8
TomM96
In previous relevant discussion, OldNuc made same suggestion.
Oh Nnnnnooooo! bad trans fluid leak out of axle! fixityourselfer S-Series Tech 6 04-27-2012 06:11 PM
Transmission leak, axle seal question?? jackl S-Series General 4 07-23-2010 06:33 PM
manual transmission axle seal leak! Silversand Astra General 2 02-17-2010 11:36 AM
02 Vue AWD Right Rear Axle Seal Leak coolgreany Vue Tech 4 08-10-2009 02:42 PM
1997 SC2 AT leak - Not Axle Shaft Seal? IL97SC2 S-Series Tech 11 12-03-2007 10:53 PM
